Question about Air Tools & Compressors
Nailer worked a week ago now only shoots air and will not drive a nail.
  • enell895 Feb 14, 2010
    The nailer is a Craftsman 16 Ga Model 351-18315. I have a parts diagram, but would like to find a site thst would show me how these things work.
    Thanks, Ed
  • edward woodard May 11, 2010
    needto know type of nailer. but check that you was given the right nail also that the nails are feeding into the nose
  • 21 Answers
Be careful about oiling some of the craftsman tools use grafite piston rings and are oilless tools
Posted on Mar 17, 2010
  • Michelle Crawford
    Michelle Crawford Jul 09, 2012
    soooo.....I've come across this post two years later, and apparently several weeks too late; I bought the same model nail gun at a swap meet (very cheap for a reason I've found out); I knew gun needed some work; first thing I did was clean/oil the gun. After taking it apart, found piston needed replaced and it is indeed graphite; now no recoil is occuring of piston inside cylinder. I used synthetic royal purple maxfilm on it; what can i do to remove this oil? Michelle
    New Friend:
  • 109 Answers
Try oiling gun, if that dosent work then try opening the gun and looking for worn or broken orings. replace as needed
Posted on Feb 16, 2010
My pneumatic nailer
ok, so your nails are correct size gauge, and the right length too?? sometimes when shooting at 120psi into pine the nail is blown through the material. test it on something first something thinner that you can see if its working at all, or put in like 5 nails and see after you shoot if you still have 5 nails in the magazine.
if so make sure, nothing is obstructing the magazine chute to the driver, also make sure the nails are in the correct slot for them to be struck. keep me posted.
Mar 12, 2016 | Stanley Bostitch SB1664FN 16 Gauge...
Dc628 wont drive nails all the way
Its all about power. If you have air pressure and its the right nail it will shoot. If its oak or maple nope it most likely cant drive it up. If your pressure switch has a 90-120 spread, it will work at 120 and fail at 90. You sometimes can good results by bumping it up 5# or so without the pop off loosing its cool.
Nov 20, 2012 | Dewalt Cordless Finish Nailer Kit
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
NV45AB2 worked great a year ago.hooked it up last week and it only shoots the nail 1/4 inch in a piece of wood and it wont advance the next nail.My framing nailer works so the hose presure is good.
if you havent used in a year the o rings could be dry and you can try and lubricate them, but sounds like it needs them replaced. You can try going to Nailgundepot.com and buying an o ring rebuild kit from them. It contains all the needed parts except for the grease to lube the o rings. Let me know if you need more help
Dec 23, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Will work fine for one or two nails and then nails jam in the gun or it shoots two or three at once.
This is iffy... but PC nailers are nit picky. If you used someone elses nails, it can (and will) jam and mess up.
So, if Porter Cable nails are being used, clean and lube the nail shoot (with a few drops of air tool oil).
If that does not work, Invest 19 dollars in a new, 18 guage nailer at Harbor Freight. I have 2 of those and they have been trouble free for 3 years.
Nov 15, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Air Tools & Compressors Logo
155 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
