Question about Toro Lawn Mower With Toro Power Tools
268H Wheel horse model 72105-99000001. How do I change drive belt.
3 Suggested Answers
harlan301
  • 205 Answers
SOURCE: I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Posted on Oct 13, 2009
Give me more info on your Mower...like 10 hp, size of mowing deck, year it was built, and how many belts it has!
Hope to hear from you soon.
Joe
Posted on Sep 02, 2012
Need a manual for Wheel Horse 520-HC!
https://lookup3.toro.com/request/request.cfm Go to this website and put in model number and you can download a manual and parts book.
May 31, 2012 | Garden
I want to purchase a drive belt for wheel horse 16-44 HXLE model 79107 where can I do this?
The belt part number is Toro 93-3884. Just search google for this part number.
They are around $50-60.Also you can purchase from sears . com
or here: http://www.m-and-d.com/TOR-93-3884.html?mv_pc=00015
J
Mar 07, 2011 | Toro Garden
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Jul 18, 2010 | Toro Garden
Loose drive belt on my 1990 Horse model tiller. The belt does not seem to be worn, is not cracked or burned, but is too loose to drive the tiller tines or the wheels.
As I recall, there is an adjustment on the wheel that puts tension on the belt. Look to see if you can figure it out. Watch the wheel as you pull and push the lever. It should be pushing the belt very tight. Take a look. If you cannot see how I would recommend you go to a store that handles them and ask questions. Be suprised how much you can get from a salesperson even though you are not buying. Good luck...Lee
May 28, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower drive slips , not belt clutch, assembly. any adjustment? or anyway to fix it?
I hate to tell you this,but not much you can do. I had a toro wheel horse 12.5 hp the drive belt would slip,made it a little better by putting on new belt w/belt dressing,but would still do it especially under load or up hill,or starting in higher gear. Unfortanately,it was one of toros downfalls on a lot of models,and FYI if you think altering the tension pulley to hold the belt back more will solve it,your wrong,all that will do is make you lose use of your clutch.
Aug 08, 2009 | Garden
Belt configuration
go to www.toro.com and near the bottom is a tab for parts and manuals. You can try there.
Aug 01, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
329 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
