Question about Sangean PRD2 AM/FM/TV Radio
LCD display has gradually disappeared, now I have nothing. I have had this problem with other sangean products. Is there something that can be repaired? If so where can I send it for repair? Please advise. wdruce@att.net
  • joeverip Mar 16, 2008
    I've had the same problem for months. Once I unplugged it and when I replugged it in the LCD numbers came up normal. I saw one other post with a similiar Sangean problem, the fix involved taking it apart, washing the board with alcohol, etc. It didn't say it worked! The radio is great, but ... I can almost make out the numbers at times but it's not good. I need a clock radio I can read! Joe
I've has this radio for 3 years and until yesterday it has performed flawlessley. I've run it on D batteries that whole time.
Yesterday the batteries died and when I replaced them the screen was blank... I took out that batteries and found the AC cord in the box and plugged it in, screen still blank.
I tried new batteries, screen still blank. everything else working perfectly. But I use this radio as a sleep radio at nights so I need to see the screen to set the sleep-time.
I took out the batteries,and disconnected the AC power for 30 minutes. Put back the fresh batteries and BINGO... screen is working perfectly again.
Posted on May 25, 2008
This is a defect in the radio. Reportedly this issue was resolved in later vamps of production, but it still seemed to persist. We discontinued this model due to this exact reason. At this time there is no other solution and the factory can not tell us what the problem was and simply pointed to the LCD.
Posted on Mar 18, 2008
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
Why does the display appear and disappear after 2 seconds of being plugged in, and I cannot get it to work?
This could be a setting for a timeout of the LCD screen.
It may be a defective product if you cannot print or send test prints.
May 25, 2014 | Staples Office Equipment & Supplies
My omnia 7 LCD abnormal display. The LCD takes time to light up and display nothing.
You may say the display back light is not bright!There is the image, but a dark?If that is so, said display lamp is not lit .Need for a period of time will gradually light up!This may be associated with an operating voltage, at the same time, the display of inverter would let check design does not reach the designated position!Somewhat similar to " light " the voltage is not enough is not lit!You can try, don't open other electrical appliances, the first open display, and then, again other equipment!If the screen is fuzzy, so, I think we should display inside the PCBA plate has a problem!USB Data Sync Cable
Sep 05, 2012 | Eforcity Samsung GT-i8700 Omnia 7...
The LCD on my car radio doesn't display all the digits. It appears to work better if the temperature of the cabin is cold. Gradually, all the characters disappear. If I press on the display, some (but...
Could be that the display has developed a fault where the display is losing it connection. May not be repairable. You may have to find a used one from a wreaking yard or buy a after market replacement.
Feb 11, 2010 | 2002 Mazda Tribute
The display has gradually disappeard on all three handsets
that is an celphone? if celphone i think the problem is the LCD screen have the problem you can go to the service area and ansk to replace other LCD of your celphone that is the best way to do. you can not solve that even you change your battery or anything...
Jul 29, 2009 | GE 25952EE1 Cordless Phone
I have lost my LCD display, the numbers are disappearing from the screen. Is there something I can do to get them back, I love my phone but am not happen without the CID
Check the backup battery in the phone... it may be located on the bottom of the case, or under the reciever cradle.
If there is a power adapter, check that it's connected and it's stil providing power to the phone.
Jun 03, 2009 | Uniden Cordless Phone
Viewsonic VE170 dislay problem
Your LCD inverter is giving up. You can either buy a new inverter but its a bit expensive
http://www.lcdpart.com/Products/cpc1151r0015.html,
or you can have it fixed by some electronic expert.
Nov 19, 2008 | ViewSonic VE170 (Beige) 17" LCD Monitor
Digital Radio Digitor by Sangean PR-D3L The LCD display has slowly been failing and is now 95%failed. Is there a spare part or other magical solution available
I have fixed the display on a Sangean PR-D3L that had faded to less than 30%. It was a bit involved and required pulling the radio apart and desoldering a metal sheild off the back of the display board to reveal the "zebra strip" connector for the display. I used a bit of heat and pressure on the connector strip where it contacts the circuit board - presto 100% display. Don't know how long it will last tho'.
Oct 08, 2008 | Audio Players & Recorders
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
Sangean PRD2 AM/FM/TV Radio Logo
509 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
