Question about Apple iPod classic MP3 Player
Cant unlock volume on i pod 160gb classic - Apple iPod classic MP3 Player
  • 864 Answers
unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Posted on Aug 26, 2010
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
160gb Apple Classic I pod screen frozen!!
my ipod classic on the face it's showing a picture to plug it into the wall and when i do it's still not charging so what should i do or is it the battery will someone please help me out.
Oct 19, 2010 | Apple 160 GB iPod Classic (Silver) +...
When i turn up sound on i pod it automatically turns its self down
I suspect your volume limit has been set low so go to settings and then volume limit. Use the click wheel to select your maximum volume.
Nov 02, 2009 | Apple iPod classic MP3 Player
The volume control is locked
The ONLY way to resolve this issue is to restore using iTunes. iTunes will restore the iPod. It is recommended to only have one iPod connected to one computer at a time. Also shairring your library should not cause the iTunes to not restore your iPod. If you are not wanting to restore the iPod due to not wanting to loose music, you will have to choose between unlocking the volume limit and keeping music.
Jun 24, 2009 | Apple iPod classic MP3 Player
I can't turn up the volume and i don't have the owners manual
The clickwheel controls the volume - you have to run your finger counter-clockwise while a song is playing.
Here is the manual:
http://manuals.info.apple.com/en_US/iPod_classic_Features_Guide.pdf
-Tha Mp3 Doctor
Mar 30, 2009 | Apple iPod classic MP3 Player
Is the volume control on the ipod limited by the pod or the earphones? i would like to get more volume, but i do not know if i need to purchase a new set of earphones or i am limited by the pod. would like...
yeah the volume is limited to the pod... iv also thought about that it doesnt play very loud does it... im sure the only way it would be louder is if you got an ipod home with larger speakers...
Mar 24, 2009 | Apple iPod classic MP3 Player
The volume is not loud enough on my i-pod classic
There is a volume limiter under "settings", check to be sure its turned all the way up (you actually have to click the center button to save). Also you will find "Sound Check" being turned on greatly reduces volume.
Dec 31, 2008 | Apple iPod classic MP3 Player
I pod nano pink
There is no unlock for the volume. There is a volume limit which is based in settings, so try that and turn it all the way up. If you still have no sound, try using a sound device with a docking bay. If there is sound it means that you're headphone/hold cable is faulty, otherwise, if there is no sound from headphones or by docking then there is a fault with your logic board.
Nov 04, 2008 | Apple iPod classic MP3 Player
How do I Unlock Ipod screen if I forgot the 4 digit password?
i have the same problems how can i solve this problem
Oct 15, 2008 | Apple iPod nano
Apple iPod classic MP3 Player Logo
407 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
