A couple months ago when my maytag washer had a problem..i was able to find online how to run the self diagnostic test mode with all the default codes. now i need the same thing again and cannot remember where i found them at. can u please help.
  • 714 Answers
Try REPAIRCLINIC.com
Posted on Feb 04, 2010
Model # MVWC425BW0 Maytag Centennial
May have to reset your washer to default mode or unplug for a few minutes then plug back in. It should work after that.
Mar 11, 2016 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Coninuosly repeats spin cycle, any suggestions how to remedy this? I have to manually cancel the cycle in order for the machine to stop recycling through spin
I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
  • Try running it through diagnostics and see what error codes are in the memory. (Guide is linked below)
  • What are the codes? do they give any more clues?
  • clear the codes and run a test cycle.
  • does it work?
  • if it checks out properly with the diagnostics it's probably a bad control board...
Maytag Centennial Washer Diagnostic Guide
If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below.
Hope that helps! Good luck!
Jun 16, 2015 | Maytag Centennial Top Load Washer
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
Maytag washer giving error code A0
Maytag Neptune Priority One Service
(888) 462-9824 call to the company to due the error code.
God bless you
Aug 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
What does Lr indicate on a Maytag Neptune washer
Lr
  • The "Lr" code indicates that the washing machine's motor is not running as it should.
Open the top lide by removing screws holding top lid in back. Or remove bottom access panel if applicable. Find the technician diognostiuc sheet. It tells you how to test the motor and how to enetr automatic diagnostic mode. Run test it will tell you how to test the motor and what the solution is. If you have anymore questions please comment me back.
Jul 30, 2011 | Maytag Neptune Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag washer 3e fault code
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board.
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
