Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
With a small load in the washing machine it goes well for a few minutes, then I get a grating noise and the drum has difficulty in moving. I the stop the machine and take some more clothes out, it then does run smoothly. I now put less and less clothes in my machine, could you please solve my problem. Does the belt need changing?
  • 714 Answers
Belt could be slipping but if your hearing a grinding noise ,sounds like a tub roller bearing going bad trying to lock up!
Posted on Feb 04, 2010
Mystery Noise for the SERIOUS problem solver. . .with a video
You need to check every single hole in the basket/ perforated drum to make sure there isn't a screw or a nail in the hole but not through. If the noise stops at speed then it is still in or on the drum as otherwise it wouldn't be affected by the centrifugal force or it could also be a drum bearing that's going (it will not show play until it's gone and the noise becomes a loud deep moaning hum). Although many engineers will say that's a terminal fault and the end of your machine, it's not true. Yes it's a big job to replace (3 hours for a good engineer, I have done it in just over 2 with the right tools and a very big hammer) but once done, that'll be it for another 5+ years of use.
Apr 16, 2014 | Kenmore HE2 Plus Front Load Washer
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
OFF BALANCE WHILE SPINNING
spin the drum with hand to hear any noise from the bearings on the back of the drum, the drum should turn freely with no grating noise.
May 12, 2009 | Washing Machines
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Feb 23, 2007 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
