Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony 27" wont turn off!!!!
I dont know the exact model number, but it is a 27" flat tube tv with no HD. Long story short, my daughter was pushing buttons when noone was around, as it is in her playroom. When I came in, the tv was stuck on video 1 and the volume indicator was on the screen (it stays on the screen at all times) with the volume being at the lowest setting. When I tried shutting the tv off it would not turn off either with remote or front panel buttons. I can not get the volume to go up and I can not get it out of video 1 either. I left it unplugged for 3 months hoping it would reset itself since it seems unresponsive to all buttons on remote and front panel. Please help, what can I do???
  • C2008 Feb 20, 2008
    After playing with the buttons trying to find one that worked when I first noticed the problem, it didnt seem to me that any were stuck. I will try the volume down button one more time just to make sure.
  • 2,323 Answers
It looks like one of the buttons on the front panel is stuck, base on the info you have provided; the volumen down button is stuck. The remote or any other buttons will not be operative until the fault has been remove.
I would suggest to try to press the Vol. down a few times just to see of it unlocks, if that does not work, the front panel assembly will have to be remove and try again if it works with the remote or manually.
The last thing to do if none of the above works, it will be to put a new switch.
Good Luck.
Posted on Feb 20, 2008
  • Jaime Hernandez Feb 20, 2008
    It may appear that the button is not stuck if you visually inspect it, but in some cases it happens internally in the switch itself. If that is the case you will need to replace the switch.
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
My 2 year old daughter hit my sony bravia repeatedly with a shell yesterday and left some nasty gouges in the screen. they are through the top layer of plastic. can i do anything to fix it?
Model number of your Sony Bravia would really help to find out proper solution of screen scratches.
You can replace front screen in few models so let me know exact model number written at back of TV.
Thanks.
Oct 22, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
I seem to have a short in my main power switch on my astar tv
it won't be the mainpower swith problem,your tv has a fault,u wiggle the main power swith,the tv lose the memory of the fault,it's like a reset the tv,and then the tv back on again.
Mar 29, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
Need to lock television volume on high when television is shut of
Please check in TV menu for Intelligent Volume option and turn it OFF/ ON
Let me know exact model number of TV to help you more precisely.
Feb 11, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Need an instruction book
What is the exact model number please?
Oct 12, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
37inch hd sony trinitron wont turn on
You will need to replace the "D" board in the TV or have it rebuilt. This is a very common issue with these Sony TV's. This is the part number you will need A-1346-948-A
Jun 14, 2008 | Televison & Video
Sony tv timer light flashes wont turn on
Same exact thing happened to my 27" Trinitron purchased in 1998. I tried all the rudamentary stuff that Sony had on their esupport page, but nothing worked. In our case, it went out while my daughter was watching it. I think the time has come to scrap it, and consider a different television, and I don't think I'll go with Sony this time. I hope the rest of you have better luck.
Dec 05, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Mar 13, 2007 | Sony KV-27S65 27" TV
Sony 27" XBR failure
I will suggest dont ise it until someone who is qualified comes over to give you an estimate,I belive you have a lot of loose conections in the horizontal driver and output circuits,power supply and crt board.Should not be expensive to repair right now. Good luck.
Sep 18, 2006 | Sony KV-27V42 27" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
