Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a Whirlpool Refrigerator Model FD5FHAX5B01. The ice dispenser motor does not run. The unit does make ice and the water dispenser works OK. Chris M.
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator ice despenser
To All With This Same Problem ,
Remove the top freezer door hinge cover ( 1 screw holding it on ) , and disconnect the plug there . This will disconnect the power to the door dispensor .
Using a butter knife or small screwdriver , insert it in the bottom of the dispensor cover between the grill and the cover .
Push down and in wards , to force the bottom of the cover outward , being careful not to break the 2 or 3 built on plastic clips on the cover .
After the lower portion has been disconnected , lift the cover up to disconnect the top clips and then remove the plug on the cover .
The white piece on the dispensor now visible , is the bracket control .
The switch on the right side , is for water , the switch on the left side , is for ice . Usually , the ice switch , has a broken " spear " , which holds the switch in place . The whole bracket control , pt # 2180226 , will have to be replaced . Only 2 or 4 screws hold it on .
This part is easily replaceable by the consumer .
Just be careful when installing the switch , not to break the new " spears " and be sure to reinstall the plastic " spacers " in the same spot on the new bracket .
When reinstalling the dispensor cover , slip the top on first , and just lightly " pop " the bottom back in place .
Posted on Oct 09, 2009
Ice maker not working
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker
I ASSUME THAT THE UNIT IS MAKING ICE BUT NOT DISPENSING IT.YOU NEED TO CHECK IF THE MOTOR THAT ROTATES TO DISPENSE ICE IS WORKING OK.THE BEST WAY TO DO THAT IS REMOVE THE ICE DRAWER COMPLETLY AND CLOSE THE DOOR AND LISTEN FOR A LOAD ROTATING NOISE.IF YOU DONT HEAR ANY OPEN THE DOOR AND TURN THE MOTOR SHAFT AND SEE IF IT TURNS FREELY.IF IT DOES NOT THAT IS YOUR PROBLEM GET THE MOTOR CHANGED.FEEL FREE TO ASK ANY OTHER QUESTIONS.GOODLUCK.MOHAMED
Sep 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice dispenser motor not working
try removing the ice bin from unit, try using dispensor now, can you hear it turning now??? if so empty your ice bucket possible frozen water on bottom of bucket preventing auger from turning
Feb 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
