Question about HP Photosmart C7280 Printer
I have a HP C7280. When printing the text is very light. Like it has a clog or something. Ran alignment and it says alignment failure. I run the head clean. and it still prints super light.
    Genius:
  • 1,018 Answers
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 05, 2010
My HP Photosmart c7280 will not print pink or magenta. How can I fix this issue?
Sounds very much like you have a clogged printer head you should run the deep clean procedure form the printer dialog. If that does not fix the issue you may need to replace the print head.
Jan 28, 2015 | HP Photosmart C7280 All-in-One Printer
My black doesn't print. It wasn't printing anything, but since I used the "clean heads" application, it now prints faded black. Obviously a clog or something. WHat can I do?
Sounds like a very bad clog. Sometimes one needs to run the "clean heads" routine several times to really flush it out. That can use a lot of ink. Using an inferior grade of third party ink can cause this problem...but I'm not slamming third party inks, as I use them myself but am careful to get remanufactured cartridges, and not refilled ones.
Hope that's helpful.
Jan 08, 2011 | HP Photosmart C7280 Printer
My magenta ink is not showing up on the diagnostic test. Print is coming out with alot of green and blue colors. I have a C7280 Hp all in one printer. Mickey
Use the HP Printing Assistant software to run a "nozzle check" -- to ensure that each of the 3 ink-jets is not CLOGGED, and therefore is not jetting ink onto the paper. If necessary, run 3 (or 6) "head-cleaning" cycles.
Then, try a different tri-colour ink-cartridge.
Dec 14, 2010 | HP Photosmart C7280 Printer
My HP C6150 prints pictures fine but the text is incomplete. I have tried different ink cartridges and have cleaned print head and done a cartridge alignment. What else is there?
1. During the cleaning of the print heads you probably clog some of the jets that distribute the ink.
If you didn't use the proper cleaning procedure you may have damaged the print heads.
the color heads are probably not affected therefore the pictures prints come out clear.
Mar 23, 2010 | HP Photosmart C6100 All-In-One Printer
When I print out something, like a self-made label (basically with a box around the text), the box comes out crooked every time I print. Help!
check the manuall to re align the printer head, or search google how to re align hp deskjet d1341 printer head. hope this helps
Dec 04, 2009 | HP Deskjet D1341 InkJet Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Not printing black
To align the printer from the control panel
1. Load letter, A4, or legal unused plain white paper into the input tray.
2. Press Setup.
The Setup menu appears.
3. Press to highlight Tools, and press OK.
The Tools menu appears.
4. Press to highlight Align Printer, and press OK.
5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
Recycle or discard the page.
A success or failure message appears.
Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
cartridge.
6. Press OK to continue.
7. Recycle or discard the page.
Oct 13, 2009 | HP Photosmart C7280 Laser Printer
Wont print black
This worked for me on C6180
Good luck and let me know
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 31, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Printer Logo
124 people viewed this question
Seeker5211
Seeker5211
