Question about WYSE Winterm 1125SE Network Terminal
What is the default userid / password for a Wyse 1125SE Thin Client's configuration setup?
SOURCE: Hardware reset Wyse S30
hold down the g key on boot
Posted on Jun 13, 2007
  • 9 Answers
SOURCE: network printer through thin print in wyse s10 model
not sure look in the manner
Posted on May 20, 2008
SOURCE: How to reset thin client password
Have you checked here? http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=339214&prodTypeId=12454&objectID=c01499771
Posted on Nov 10, 2008
SOURCE: Wyse S30 thin Client with Ubuntu
I played with those a lot with the LTSP and finally made it work...
All in all, the problem is that the X.org cannot autoconfigure the graphic chip of this client. On ubuntu 7.10 you need to force it to use the amd driver and cannot do it from the LTSP.conf file.
In your LTSP.conf file, you have to point to a xorg.conf file specific for your s30 thin client (I called it s30xorg.conf). Then you need to build this xorg.conf file (lots of help on the net on how to do this) and place it in the right folder. (The folder is probably not the same than on my system but it should be pretty obvious or at least written in the manuals or help files where to pu it). In this xorg.conf file, you will need to specify the amd driver and some standard vesa resolutions and refresh rates (also widely availavble on the net). Then dont forget to rebuild your LTSP image with those new files in the tree.
If I remember correctly you will also need to disable the ubuntu splash screen from another config file somewhere... I am sure you will find which one.
Then voila.
Let me know if you can make it work... if what I said is total gebrish, go on reading everythin you can find on the net until you understand what is here.
Thanks
Posted on Dec 04, 2008
SOURCE: How do I enable print screen botton
Depending on what keyboard you use, you may have to press the "F" toggle key to enable print screen.
Posted on Mar 03, 2009
How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Oct 03, 2012 | WYSE Winterm 1125SE Network Terminal
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
Black boxes
In the "experience" tab, uncheck the "bitmap caching" box and the problem will disappear. This is checked by default, but causes the black boxes in most situations unless you uncheck it.
Feb 25, 2009 | WYSE V90 Network Terminal
Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
WYSE Winterm 1125SE Network Terminal Logo
118 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
