Question about SanDisk Sansa Clip MP3 Player
No cord - SanDisk Sansa Clip MP3 Player
  • 23 Answers
Go to Best Buy, Radio Shack... (or any local electronics store), take your player with you. A sales associate will be there that can match up your player with the appropriate USB cord.
Posted on Feb 04, 2010
What kind of electrical cord does hct flat screen tv uses?
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 07, 2014 | Televison & Video
I need replacement power cord
Sep 05, 2014 | Coby LEDTV2326 23 TV
I just purchased my fryer at garage sale today, it's missing the cord. What type do I need to get and where can I find it. Thank you,
Hi and welcome to FixYa, I am Kelly.
These cords (unless the magnetic type are available at most hardware stores ("Woods" / Woods Industries or Coleman Cable are the product brand names.) These cords are usually in the area of extension cords.
Having said that... The distance between the pins is the difference. There are 1/2" cords 11/16" plug cords and 1 1/16" cords. I need to know the distance between the pins center to center of your fryer connector terminals.
Most Fryers use a 3 Ft cord and roasters use a 6 ft Cord. You cna use a 6 ft cord but do NOT use it for an extended period. The cord you purchase must be wire gage 16/2 NOT 18/2 in wire size.
The 18/2 gage will only handle 1250 watts.
The part number of the cord will be either 0290 or 09326 (You can net "IMAGE search" these for sources)
Here is one source for the cord.
http://www.hardwareandtools.com/Coleman-Cable-0290-6-Foot-Black-Appliance-Cord-0429928.html
If you have the magnetic base / end plug let me know and I will find you the correct plug.
Just repsond here and say you need the magnetic recepticle cord.
Thanks for choosing FixYa,
Kelly
Mar 27, 2011 | Masterbuilt K5713 Deep Fryer
I pulled the pull cord right out of it s hole. So I unscrewed all of the screws to fix it but i cant unscrewed the fans screw ????
There should be no need to remove the flywheel (fans?) to repair the starter cord. The starter mechanism should have come free of the left side housing so that everything you need to deal with is in that package. Did the cord break, or just pulled the cord free of the spool inside? If the cord broke, then buy a replacement cord (about 1-meter in length) of the same size and material (no cotton cord). Thread the cord into the spool center where there is a hole for the inside part of the cord and bring the end out of the hole. Melt the cord end, and then tie an overhand knot in the cord. Pull the knot back tight and proceed to wind the cord in a CCW direction around the spool until you have about most of it wound. Pull on the cord to wind the internal spring several turns and wedge the spool so that it won't unwind the spring. Wind the balance of the cord until you have about 8" left--feed that end through the outer hole and into the handle. Melt the cord end, then tie an overhand knot in it. Stuff the knot into the handle cavity and remove the spool wedge. Try the cord several times to make sure the spring pulls it back firmly and allows ample cord pull-out. Hope this helps!
Jan 29, 2011 | Garden
I have a huskvarna 254XP and I contiue to break the pull cord after 3-4 starts, I must be replacing the cord wrong. what is the proper installation of the pull cord?
The cord ends need to be melted somewhat, then an overhand knot tied to retain both ends. If the cord is breaking along it's length, the cord may not be heavy enough--check with a local saw service shop for the correct cord and buy about 1-meter of length to make sure that you are not reaching the end of the cord when pulling on it. Make sure there is nothing that the cord passes over to damage the cord causing failure. Hope this helps!
Nov 12, 2010 | Husqvarna Garden
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
Can not find power cord anywhere for my printer
part number for power cord u want to order just select ur choice and order it online or call hp in U.S 800-BUY-MYHP or for others find contact here www.hp.com
Power Cord (Europe) 8120-6262 Power Cord (Denmark) 8120-8881 Power Cord (Israel) 8120-8883 Power Cord (South Africa) 8120-8886 Power Cord (Switzerland) 8120-8885 Power Cord (United Kingdom) 8120-8882
Mar 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
