Question about Thomson 26943GE1 Cordless Expansion Handset
Pulse to tone
How to change pulse to tone
phone is 26943GE-2
  • DDablo May 16, 2008
    I cant get the phone to stay on tone ,I have to be pressin tone to get the phone to stay in tone for the call only
  • 3 Answers
SOURCE: pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
jonniewalker
  • 1031 Answers
SOURCE: Cordless telephone sw/from pulse to tone
Set the TONE/PULSE selection to Tone if you have pulse (rotary). If you don't know which
type of service you have (pulse or tone), check with your phone company.
To program TONE/PULSE for all 3 lines:
1. Press STORE/IN
2. Press 0 for PULSE or Press 1 for TONE
3. Press STORE/IN
4. Press TONE
To program TONE/PULSE for each line individually:
1. Press STORE/IN
3. Press STORE/IN
4. Press LOWER
5. Press line number (1, 2, or 3)
Posted on Aug 15, 2008
SOURCE: Switching from pulse to tone.
Hi There, I had the same problem and what worked with me was by pressing the star button before the number, or if it works with u, by keeping a hard press on thre star button for 3-4 seconds
Posted on Aug 16, 2008
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
Posted on Dec 12, 2008
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
Mar 16, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Sep 19, 2007 | NorStar Polycom Soundstation ( Phone...
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Thomson 26943GE1 Cordless Expansion Handset Logo
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
