Question about Soyo 7VBA133U VIA 694T ATX Motherboard (59792)
Does not boot looking for repair - Soyo 7VBA133U VIA 694T ATX Motherboard (59792)
  • 634 Answers
Repair your computer by inserting windows XP disc.
OR Format your computer.
Posted on Apr 08, 2010
  • Soyo Master
  • 11,800 Answers
Your motherboard is absolutely ancient. If you need a similar one search thru junked pc's . Or just find a newer pc.
Posted on Feb 07, 2010
  • 728 Answers
I don't know how computer technical you are, but it sounds like you knw a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, harddrive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a ide drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the case where the CPU or power supply don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, harddrive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that,
Now If no changes happen after all that, then I take it one step futher and usually get a like (doesn't have to be exactly the same, but a board that the components can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
Mark
Posted on Feb 05, 2010
The steel toe of my chippewa motorcycle boots hangs down across my toes inside the boots
first, i would not wear them till you get it fixed. is there any warranty on the boot; if so, i would use it. also, look for a boot repair store. try redwing or the like.
Feb 18, 2012 | Clothing Accessories
Start-up shows "Launch Start-up recovery" but am unable to proceed
This is Vista you are running and there are a couple of options. I'll go for the easy one first
Boot and insert Vista install or recovery DVD (any Vista disc will do for this)
Reboot and hopefully it will offer the option to boot from the DVD. Take this option and follow it through until you are offered the option to install Vista or repair your computer. Just follow things though from there and it MAY repair the boot problem.
If it does not offer you the initial boot option then look on the initial boot screen for the boot options key - probably F11 or F12 - and press that during initial boot to obtain the boot options screen
Dec 14, 2008 | Acer Computers & Internet
Toshiba laptop when turned on it freezes as windows is starting
Insert the disk in the cd rom and restart your computer......enter bios and change the boot settings...to boot from cd rom......boot of the cd and look for options such as check disk....repair disk...disk tools.....do a check disk ...or run a repair.....
Once you boot of the cd it will give you step by step details as how to repair the OS....
If you are unable to boot from cd..download a UBCD and created a boot cd this is much easier to use...
keep me posted
Cheers!
Nov 16, 2008 | Toshiba Portege 7100 Notebook
When i turn on my laptop it boots fine, but than a black screen comes up with a blank window, and thats all
try running ur labtops repair cd u might have a virus but u sound try the repair cd first
Looking Forward To Helping U Shaun
Nov 15, 2008 | Computers & Internet
Gateway MP6954 laptop running XP with all updates won't boot. It gets to the Windows XP screen and stays there looking like it wants to boot up never does. Help DG
Open and check the ROM...remove any CD if there is...if not
Try to repair the OS...use you Xp CD boot of the CD...select check disk with repair options
keep me posted
Nov 14, 2008 | Computers & Internet
Ubuntu Repair Grub
Do you have any other OS's installed? Its with the Grub. mostly looking for another OS. let me know.
Aug 06, 2008 | Canonical Ltd. Ubuntu
Mbr Missing
you can have a look on the internet for a boot cd called hirens boot cd and download burn it and boot it from cd then go into mbr tools and choose a mbr program to repair and it should work after that
Jul 13, 2008 | Maxtor Hard Drive
Trying to do a repair installation
OK, that screen is the bios for the laptop. Don't do anything in there. (except check under boot and make sure the boot order is cd then hard drive) Once the boot order is correct, just boot from the cd rom, and to do a repair, just keep continuing past where you are asked to enter F-8, the next screen will offer a repair for the windows installation- press R. That keeps your files and programs, but reinstalls windows. Good luck
Aug 11, 2007 | Acer Aspire 3680 Laptop
Soyo 7VBA133U VIA 694T ATX Motherboard (59792) Logo
66 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
