Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
How come the lamp does not have a good life span
Sony wega KDF-55XS955 - HOW DO i REPLACE THIS LAMP??
Posted on Feb 06, 2010
    President:
  • 2,030 Answers
Just by nature of the type of lamp it is; its not desgined for long life.
Posted on Feb 04, 2010
Lense hours
Hello muhammad
Projector's lamp life is said to be, not with the lens life. Lens is made up of glass. But lamp will go weak. the life of lame will depend on how much time the projectior have used. Normal life of Panasonic projector bulb spans between [1800 to 2000] continous use. It means, if we take the low life span of the bulb as 1800 Hours [1800/24=75 Continous days]. If we use it for 4 hours a day, the bulb may last for [1800/4=450 days ie 1 Year and 85 days] OK.
Dec 12, 2011 | Panasonic Videoprojector PT-LM1E...
Tv on my samsung p4663w/hl does not turn on. lamp light flashes on front of tv picture does not work. no sound , bulb has no marks on it to show that it is bad
Tv projection lamp have a life span like any other bulbs light sources.Tipically life spans of these tvs projection lamps are around 20,000 hrs of useages.That average out like about 1 1/2 or 2 years and around 4 or 5 hours of the tv is on and watching it everyday.Now the front tv bazel frame of the tv.The word "LAMP" LED light indication is on or flashing are indication of the tv projection lamp life span are over and the tv must have it projection lamp to be replacement to another tv projection lamp.Projection Lamp fillerments tipically dies out when it reaches it life span.Mark or burns on the projection Lamp,will not show or be there,if the tv projection lamp run it natural life span cycles.
Aug 03, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
SCREEN IS BLACK ,BUT HAS SOUND
this is most likely just a lamp issue this lamps a made to last a average life span of 2-3 years of use
replacing the lamp should fix your problem that is the first thing to replace in this cases
here are few good online stores that have the lamp you need
http://www.discounttvlamps.com/915P028010-Housing-p/mitsubishi-915p028010-enc-ph.htm
http://www.discount-merchant.com/Mitsubishi-915P028010-915P028A10-Lamp-Enclosure-p/mitsubishi-915p028010-lamp-enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Nov 05, 2010 | Mitsubishi WD-62528 62" LCD HDTV
My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
Replace lamp in tv to get problem solved.
Thanks.
Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
The power lamp flashes when turned on, no picture???
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
May 14, 2010 | Toshiba TP55H60 55" Rear Projection...
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Jan 27, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Dimmer Usage questions
Yes. The use of dimmers can reduce the use of electricity and, thereby, save money and help conserve the environment. Dimmer use can also increase the life of the lamps (light bulbs) being controlled.
Aug 27, 2008 | Leviton Acenti Natural 1000W...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
145 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
