Question about Peavey PVM 22 Microphone
Need wiring info - Peavey PVM 22 Microphone
Hi - looking to fit a Mongoose MAP80 upgrade alarm to a 2011 Colorado dual cab - does anyone have wiring diagram or info for door trigger, arming/lock wire & disarming/unlock wire Thanks
Peter, This is what I found on google search, you can also try google search Mongoose MAP80 upgrade alarm wiring instruction as there is a lot more info. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.mongoose.com.au/vehicle-installation-manuals/MAP80inst.pdf
http://www.mongoose.com.au/vehicle-wiring-holden/colorado_2009_2010.pdf
Aug 04, 2016 | 2005 Holden Rodeo
What color wire coming off the engine harness grey or brown connects to the blue signal wire on the 02 sensor which color is the signal wire to the computer
posted 3 times now and forget to say FRONT SENSOR>
right, not the Rear 02 sensor....?
and still no engine stated.!
nor country, (USA calif, usa FED, or canada)
strike three you are out.
sorry.
there are 3 engines,
based on all 3 engine schematics, my wild guess
is 7AFE engine. (the brown wire clue) 1,8L
4AFE (1.6L)
or 1ZZFE engine, DOHC 1.8L
Feb 28, 2016 | 1997 Geo Prizm
I have a Bosch hbn 3650 and it has stopped working when u turn the knobs the clock still works but nothing else
I need more info electric or gas? If electric you need 240 volts or two legs of 120v. some times the clock will work even when you lost the other leg of 120v. Unplug or shut off breaker for about 1 min. if that doesn't solve problem pull plug and check wire connections at the other end of plug connected to stove. sometimes they become loose and cause damage to wire connector and wires. if wires are tight and no damage, check all other wires for tightness and damage. Sorry I need more info
Apr 29, 2014 | Ovens
I have a Dayton 5X848N relay switch that needs connected to a well pump. how is it wired
go to www.ehow.com and type in the search box
"relay switch wiring"
and you will pull up 6 web pages of click on the post articles
on how to wire in a relay. somewheres in all that techinical info
someone will be writing about a relay just like yours & be giving step by step instruction as well as tools needed to do job.
try typing in search box---" how to wire dayton 5x848n relay into well pump.
You should also have the make and model of the well pump handy on paper as you will need this to find out where relay goes to pump motor.
If you need more specific info type in search box
*how 2 wire dayton 5x848n relay into make & model well pump*
try that on google.com.;bing.com;ask.com;yahoo.com as well as
ehow.com
they all have search box on upper right coner of web page & they all answer questions with pre writen info.
Oct 12, 2013 | Dayton Dryers
I am trying to wire a double toggle switch one would work an outside light and the other the garage light. help!!!!
I can probably help you, but I need more info. Are you replacing a single switch that operated both of these lights together? Do you have 3 black wires and three white wires in the box now? Are the 3 white wires all connected together? Were 2 of the black wires connected to one terminal of the old switch, and 1 black wire connected to another terminal of the switch? ----- I'm doing lots of guessing here so that you understand the kind of info I need.
May 10, 2010 | Cooper Lighting Lighted Switch
Whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
Dec 17, 2009 | Crane & Co Crane Plumbing 2386W Oval...
2005 Toyota Camry JBL Radio Replacement: Info button issue
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Mar 22, 2009 | Car Audio & Video
What rca plugs am i suppost to use for wiring a sub? there are 5 wires, a blue, 2 white, an 2 red????
need more info...there should only be two rca wires used going from the head unit to the amp....unless your doing something different...via need more info....hope this helps!!
Mar 22, 2009 | Jensen Car Audio & Video
Wiring
not enough info... are they at the bottom of the colom? the top? under the horn button... where? most likely... it you're talking about the wires that are on the ignition switch wiring harness... the 2 wires off by theirselves... it's probably the buzzer contact wires... need more info man
Oct 20, 2008 | 2000 Chevrolet Blazer
Peavey PVM 22 Microphone Logo
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
