Question about Dryers
My dryer makes a loud screeching noise coming from the fan at the end of the motor, any ideas
  • 10,319 Answers
The belt runs off the drum with a tensioner attached. It sounds like the bearing in the pulley is locked up causing the noise
Posted on Feb 04, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Belt is tight and drum trns. Loud noise from motor. Are there gears in the motor?
I do not know your make or model but there are no gears in motor.It sounds like the fan on the end of the motor shaft is damaged and that is where the noise is coming from.
Hope this helps.
Aug 21, 2010 | Dryers
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
May 05, 2009 | Amcor PLM16000 Portable Air Conditioner
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Fan motor has loud screech.
Check for oil ports on motor. Usually red or yelloe plug in caps. No more than 20 drops of oil. I usually use sewing machine oil.
Apr 26, 2009 | Heating & Cooling
Dryer screeching when on
likely has a slipping belt , it will smoke before too long,
unless something got between the drum and door and is scratching .
Mar 22, 2008 | Dryers
Dryers Logo
181 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
