Question about Samsung SGH-A137 Cell Phone
3C012301 I turn the phone on and it flashes with this code at the top - 3C012301
How do you flash a nokia phone?
  • Connect your device via USB cable and make sure it's turned OFF. Run Phoenix software. Select "NO CONNECTION" as connection type.
  • Click File then select "Open Product"
  • A window will appear, select the device model and the corresponding product code of your phone. To find your product code - Press *#0000# on your dialer while your mobile device is on.
  • Select "Firmware Update" option in "Flashing" menu.
  • Press "..." button on the top-right corner of the window to select the language pack/product code You want to use on your flashing. Click on the product code / language pack that you have selected and press OK button.
  • It will now show the Product code you have selected. Tick the "Dead phone USB flashing".
  • Click on "Refurbish". Then you'll get a pop-up window, follow the instruction. If it did not work, best option is to Disconnect the USB cable from your device. Press and Hold the Power button of your phone for 8 seconds. Once it vibrates, release the Power button and immediately connect the USB back into your phone's port. Then you should see the flashing starts.
  • After some seconds of flashing, it will pause and prompts for the same instructions as above. Do the same trick as mentioned in Step #7.
  • When the update process finished, a window will appear "Firmware updating succeeded". Your phone will automatically restarts when flashing is done. After that, you can safely remove your data cable from your device. In some cases, when using a CFW, it wont says "Firmware updating succeeded" but will just say"Flashing Completed". When that happens, the device screen will show "Local mode" or "Test mode" or inNokia Logo. You can try to turn in off by holding the Power button for 8 seconds untill it reaches the multiple vibration. Then restart your device - most of the time it works after that. But if not, you have to repeat the flashing process again.
  • Mar 14, 2016 | Nokia Cell Phones
    Nokia 2700 display a white screen and turns off. how to repair it nothing is visible.
    It seems that your phones firware has corrupted.you musttake it to the service store or if you are good enough with computers,followthese instructionsFirst download and install Pheonix. NokiaPhoenix Service Software 2011 -Download secondly Download flash file from this link Nokiaflash fileandinstall it to C / programme files/pheonix..afterfinishing this installationopen pheonix Inside theinterface at the> left top File" click there and choose "openfile" and then select the appropriate Product type i.e"whichis written in the back banel inside the battery of every Nokia(Type RM-000).Afterdoing this again at the left top count from "File"1..2..3..the 4thone is "Flashing" press there when you click there you'll seethreeicon just select the "Firmware Update" again you'll seeanother interface .Look at the product code there should be blank and put your "mousetool" at the straight end from the "Product Code" thereis a Botton and choose the code which is written in the back sideof your phone. e.g CODE:0000000.if the same code does not found, justtake one.After this you can see "Dead phone USB flashing" clickthat box .Now this is the last stage... Connect your phone with the USBtoyour PC and let the driver install ...wait for a moment.(If yourphone working).Lastly after just finished (In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "Referbish"afterthis, a message will prompt you "press power botton"press it and wait untill the phone will Restart automatically
    Oct 25, 2011 | Nokia Classic 2700 Cell Phone
    It wont turn on after it was charged.... so what can i do ?
    Oct 25, 2011 | Nokia E63 Cell Phone
    White screen display just a seconds it will turn off immediately.
    Software flashing can help you so contact mobile tech or follow the instruction belowFirst download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
    Sep 18, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
    How to flash nokia 2700c . pls give the software
    First downloadand install Pheonix. NokiaPhoenix Service Software 2011 -Download secondly Download flash file from this link Nokiaflash file and install it to C / programmefiles/pheonix..after finished thisinstallation open pheonix Inside the interfaceat the> left top File" click there and choose "open file"andthen select the approprait Product type i.e"which is written inthe back banel inside the battery of every Nokia(Type RM-000).Afterdoingthis again at the left top count from "File"1..2..3..the 4th oneis"Flashing" press there when you click there you'll seethreei con just select the "Firmware Update" again you'll seeanother interface.Look at the product code there should be blank and putyour"mouse tool" at the straight end from the "Product Code"thereis a Botton and choose the code which is written in the back sideof your phone.e.g CODE:0000000.if the same code does not found, justtake one.After this you can see "Dead phone USB flashing"clickthat box.Now this is the last stage... Connect your phone with the USBtoyour PC and let the driver install ...wait for a moment.(If yourphone working).Lastly after just finished (In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "Referbish"afte rthis, a message will prompt you "press power botton"press it and wait untill the phone will Restart automatically
    Sep 07, 2011 | Nokia Classic 2700 Cell Phone
    When i turn on my nokia3110c mobile it flashes 3 times and turn off.
    Now you can do it by yourself....just follow the instruction
    Firstly try to download this Nokia Phoenix Service Software 2010.08.004.41526 WinXP/XP-64/2003/Vista/Vista-64/Win7/Win7-64
    Secondly download
    3110c files And install it in your PC..Disconnect all usb devices.
    Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
    After loading ..Click to "Dead phone" and again press to "REFURBISH"
    Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
    Good luck.......
    Sep 26, 2010 | Nokia 3110 Cellular Phone
    I have a ATT Go phone (samsung flip phone) that flashes a red "3C012301" when you first turn on.
    take the phone to a mobile service center to have the firmware reflash on it.
    Jun 03, 2009 | Cell Phones
    Trying to get error codes
    This is an OBD1 module located under the dash:
    1st turn off the ignition.
    2. Use a jumper wire between the ground terminal "A" top right and the diagnostic terminal "B" second from top right.
    3. Turn the ignition to on but DO NOT START ENGINE.
    The "Service engine light" soon will flash the code 12 - one flash followed by 2 short flashes. it will repeat then pause followed by yuor trouble codes flash.
    Hope this helps
    Apr 12, 2009 | 1993 Chevrolet S-10 Blazer
    Samsung SGH-A137 Cell Phone Logo
    238 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
