Question about GE (PSS26MSRSS) Side by Side Refrigerator
Clogged water hose in the freezer door - GE (PSS26MSRSS) Side by Side Refrigerator
  • 1,531 Answers
You can usuall yclear this by disconnect the hose from the btoom of the door and use a hair dryer and blow warm up through the hose and also use it where the water is deispensed
Posted on Feb 04, 2010
I have a westinghouse side by side frig about 10 years old. Model number RS695V Serial number 34700050.The problem is water is leaking out of bottom of freezer door. I believe it is caused by a clogged...
The hose that goes to the water dispenser most likely has a crack in it somewhere inside the door. Usually the heat from the light in the door deteroriates the hose and lets water leak inside the door every time the dispenser is used.
Feb 19, 2015 | Westinghouse Refrigerators
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a two door 600 liter fridge the freezer side has a water drain hose which I don't know where the water drains to.I have cleared the frozen water from the drain hose,a couple of times but I know the...
The hole in the bottom of the freezer section all the way in the back is clogged. Use a metal coat hanger or something similar to stick in the hole and try to clear out the clog. The water drains to a pan underneath the fridge, and the heat produced by the compressor should evaporate the water.
Dec 10, 2010 | Maytag Refrigerators
Freezer not cold.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Freezer door pops open when the frig door under it is closed what can I do
I am going to send a quick response here to try and catch you. If you need more help just respond and I will get back to you. Check the freezer cabinet drain. If they are clogged the door can and will pop open when the other door is closed. The air baffle between fresh food and freezer allows for the air passage. the compartment drain acts as a pressure relief when it is clear. If it is clogged usually over time you notice ice building up in the freezer section faster than normal or will have this occasional leak out the front. If it keeps doing this after your sure the compartment drain is clear, you may have to replace the door seal. FYI the compartment drain terminates into a plastic catch basin under your refrigerator. If the darin hose is under water it can get covered with gunk and act s a plug. Make sure the drain hose at the drip pan is NOT under water and that the end of the hose is free of debris.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water is leaking out the bottom of door
clogged defrost drain. remove ice from bottom of freezer and take very hot water and work back and forth with a turkey basteruntil water drains. blow out with hose.
Jul 25, 2009 | Frigidaire FRS23R4A Side by Side...
There is no water coming out of our fridge's water dispenser
Sounds like your line has ice in it.Try thawing it out by turning it off and leave doors open,put pans of hot water in to speed it up.
Hope this helped.Let me know by rating me
For more help go to live chat.
len west
Jan 31, 2009 | Frigidaire FRS3R5EMB Side by Side...
Upright with door lock 13.7 cu. ft.
hi tanks for the question is there water inside on the floor of the freezer.if not check the drain tube under the freezer at the back could have a clogged drain hose thanks the appliance doc
Aug 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
112 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
