Question about Olympus WS-100 Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
My WS 100 says FULL when you turn it on. I can't erase. When plugged into the computer, it says 'setup' and the memory is full. I can't do anything.
  • 207 Answers
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Posted on Feb 07, 2010
Can't erase on my olympus WS-100
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
May 26, 2015 | Olympus WS-100 Digital Voice Recorder
HOW TO FORMAT WS-100
Hello Press the FOLDER button to choose a folder
Press and hold ERASE button for 3 seconds or longer.
The ERASE indicator will flashes
Press the ERASE button again.
Done blinks for two seconds and the deletion will be complete
Note AN erased file cannot be restored.
During this process don’t remove batteries. Otherwise data may be damage
Mar 09, 2010 | Olympus WS-100 Digital Voice Recorder
Restoring disk on olympus ws 100
I reformat my olympus ws 100 on a mac and, erase everything, and the computer didnt want to recognized it. When turn on the display showed check and went off. When turn on without connecting to the computer and without the hold the display showed no format. If you use the foward button you can change the display to yes format and press play to select. That solve the problem.
Jan 05, 2009 | Olympus WS-100 Digital Voice Recorder
WS100 solution suggested
when the device is plugged into the computer, you should be able to see the contents of the drive... you should see folders. if the folders are not there then copy the folders back to the device after deleting whatever is on the device
Oct 13, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus W_S 100 can't record/erase
the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer
Oct 12, 2008 | Olympus WS-100 Digital Voice Recorder
Problems caused by "improper device removal"
the recorder has .dat files in each folder and must not be deleted. if you still have them on your computer, then you can transfer back to the recorder and the recorder should work fine
Jul 03, 2008 | Olympus WS-100 Digital Voice Recorder
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
"full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Dec 19, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
375 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
