Question about Westinghouse L1975NW Monitor
Westinghouse L1975NW DAC-19M005AF burned resistors
I have a Westinghouse L1975NW 19'' LCD monitor with a Delta Electronics DAC-19M005AF power/inverter board. In the primary power section, resistors r131,r132,r133 and r134 were damaged/burned when a mosfet shorted out. Does anyone know the values of these resistors? Thanks!
2 Suggested Answers
  • 1684 Answers
SOURCE: I have a bad power inverter board for westinghouse
We do board level repair on LCD monitors so we should be able to repair your board. We also have the board in stock for sale with exchange. Contact us at tech@ccl-la.com or 318-447-9040
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 03, 2009
Installed new 27-D01567 power supply unit in my 19" monitor L1975nw. have green light but black screen. whats next?
Is the board brand new or used? You will need to verify the voltage (12~18vdc) feeding the inverter circuits, there is also a surface mounted fuse.
Try reading here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/#step1
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | Westinghouse LCM-19v5 Monitor
Image blinks off after about 1 second after being powered up. Cut the power off at monitor, then turn back on and it repeats. Full image from computer shows up for about 1 second then disappears. The...
Please look here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Oct 13, 2010 | Westinghouse L1975NW Monitor
I have the Westinghouse L1975NW
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Notes: When the caps went out, it may have raken out the fuse and the MOSFET in the inverter circuits with it also. http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
May 23, 2010 | Westinghouse L1975NW Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Goes dark for 5 to 10 second for no apparent reason?
Look for bad caps in the power supply, it will get worst and can take out the inverter fuse and the MOSFET.
Feb 10, 2010 | Westinghouse L1975NW Monitor
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
Jan 07, 2010 | Computers & Internet
I have a bad power inverter board for westinghouse L1975NW, not caps but board failure. Need to replace but cant find DELTA DAC-19M005 AF rev: 00A but i can find a 19M005 BF, not sure if they would be...
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | Westinghouse L1975NW Monitor
Hello viewsonic vx2235wm no power
this instructable might help http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
the dac 19m009 is supposed to simular to the dac 19m005, which is repaired in the instructable.
Apr 28, 2008 | ViewSonic VX2235wm LCD Monitor
Westinghouse L1975NW Monitor Logo
441 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
