My wd62628 mitsubishi has a whine on atart up, and continues till turned off, kind of winds up on start up and down when turned off. it's not the fan
  • 69 Answers
Sound like the colorwheel is starting to go bad
Posted on Feb 07, 2010
Cooling fan starts when switch on the engine, and the fan stops when i switch off the engine
cooling fan mainly turns on when your ECM senses that your engine is getting hot and there is no wind cooling down the coolant to cool your engine it usually kicks on when your idling or driving at low speeds to pull in the wind to cool the coolant. the fans don't need to turn on when the engine is off
Jun 01, 2013 | 2006 Mitsubishi Lancer
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Older Ruud heat pump. Fan on one side runs backwards. Most peculiar, Mama. Run cap maybe?
No the run cap will not do that...sometimes the wind can be blowing when the fan motor goes to start and then an older motor will continue to run the other way...it then will remember that and keep on running wrong...
Bottom line is that you need to replace the motor...
You can get it running right usually if you shut it down... spin it the run way and then turn on the power, but often that will only work till it goes to start again...
heatman101
Jul 16, 2011 | GE Heating & Cooling
When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
May 05, 2009 | Dryers
Whining wind like noise only in 4WD
sounds like your differential is going. alltime 4wd?
Apr 15, 2009 | 1991 Mitsubishi Montero
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Half of screen blacks out
sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Mar 22, 2007 | Mitsubishi WD62628 62" Projection HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
