Question about Hitachi 42V715 Rear Projection Television
Hitachi 42v715 has a large round yellow spot in the center of the video on the screen How do I fix this?
  • chambleebunc Feb 05, 2010
    Thank you Ill try and replace it
  • 201 Answers
The yellow spot is caused by a failure in your light engine (it is the projector part of your TV where the lamp plugs in.) There was an extended warranty but it has probably expired. You could contact Hitachi just to see, otherwise it would probably be cheaper just to replace it. Light engines can cost several hundred dollars plus a couple hundred more in labor.
Posted on Feb 05, 2010
Yellow to green tent screen to hitachi tv 42v715
You have some reason to believe it will not?
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
HOPE IT WORKS OUT FOR YOU.
Jun 11, 2012 | Hitachi 42V715 42" HDTV
Hitachi 42V515 LCD TV
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 12, 2008 | Hitachi 42V715 Rear Projection Television
I have a hitachi 50vs69a with 2 yellow spots in the middle of the t.v when powerd on.....black when off. these spots almost resemble states...there is also blue splotches in the middle of these spots. any...
Yes, if the spots are round or teardrop it may be burnt picture tubes.
Easy to confirm this by covering lens of tubes one at a time with set on and see which removes the blotches.
What happened in a lot of these sets is the set arcs and burns a black dot dead center in one or all three of the screens of the picture tubes used--fatal case and permanent.
Mar 14, 2012 | Hitachi 50VS69 50" Projection HDTV
Grenn yellow tent
the color filters are burned from heat there are three small glass filters one is red one is blue and one s green They are in the light engine.I know I have the same tv and the same problem.you have to take the light engine apart or you could replace the light engine.a lot of plugs and screws to take out just to change three colored glass plates
Feb 18, 2010 | Hitachi 42V715 Rear Projection Television
Yellow spots
I have been told by a local repair person that Hitachi might replace the light engine at no cost because it is such a big issue... has anyone hear about this... I am going to contact them directly also.
Sep 08, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
I have a Hitachi model 50V69A and have large yellowish spots on screen. It is most noticeable when watching programs with light background, like hockey games..
I havw a simialr problem mine is a blue stripe toward the center of the screen. The problem is most likely from the blue lens on mine or the yellow on yours. I was able to adjust it out somewhat and I am still tweaking it by using a setting in the technical menu called stripe.
You can access the technical menu by pressing the fowllowing on your remote:
MENU +MENU+ 8 + SELECT
Hope this helps
Jul 02, 2009 | Hitachi Televison & Video
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
Hitachi 42V715 Rear Projection Television Logo
194 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
