Question about HP DeskJet 9800 InkJet Printer
Colored documents have light and dark "bands" when I print, especially noticable when I have a large section of the print in a smooth uniform color. What's up?
    Genius:
  • 1,011 Answers
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 05, 2010
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
I would like to print some color pictures in black & white but I cant get it to do it. Any ideas
The black ink produces dark images while color ink produces multicoloered images. Once pictures that appear in color on the computers word documents are dispensed for printing, the color ink makes possible requests. It is impossible to request black charaters from colored ink on the printer.
Feb 04, 2011 | Lexmark X4580 InkJet Printer
I need instructions on how to recalculate the timer. The yard and driveway lights come on during the day instead of the evening. I didn't put the system in....new owner....can't figure out the timer...Help
The RED tripper is for on. The black tripper is for 'off' and the dark colored section of the dial is for P.M., the light colored section is for A.M. Move to desired run times.
Jul 04, 2009 | Malibu Hardware & Accessories
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
My canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Will not Print Text
Replace print Head/s with new, oand check cost against new printer with warranty and gen new inks probally more economical. Welcome to our Disposable world!!
Oct 19, 2007 | Canon MultiPASS C555 InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
