Question about Behringer Eurolive B212A Speaker
Eurolive B215A, led clip on, bad audio, low power in the max volume.
3 Suggested Answers
  • 5603 Answers
SOURCE: Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Posted on Mar 31, 2010
lancejonesmu
  • 3 Answers
I see no cracks in mine at all but the red light stays on and there is no sound. I plugged the same part in from my second speaker and the red light goes off and the speaker works fine. I am not sure how to find out what is wrong with this board that h as the volume, inputs and EQ on it. Does anybody know the most likely part that would go out on it? All parts look good, no signs of blowing out.
Thank You,
Lance
Posted on Jun 14, 2015
How to replace Behringer Eurolive B215A Amplification
Is there any fuses inside the unit or just the one on the back inside that cylindrical fuse holder that you can push, twist and remove? Mine will not power and I want to open up the box if there is any fuses there and I will check for cracks near the pots, etc. as well while I am inside the power box. I already removed the box fromt heback. Just need to open it up now.
Apr 07, 2015 | Behringer Audio Players & Recorders
Remove woofer from behringer B215A
you want a woofer replacement? ... it's possible but you need to put whole your speakersystem in a program and the change you get the values you want is slittleeee. No if you need to ask if you have to change.... noooooooo. It's to complicated and only can ve done by peoples with real knowledge....
Apr 05, 2014 | Behringer Eurolive B212A Speaker
Eurolive B115D Powered PA Speaker
I would guess this is less than 3 years old and assuming you registered you will have a 3 year warranty so they'll probably fix it for you FOC
Jan 07, 2014 | Behringer Eurolive B115D Powered PA...
When connect power, Clip signal On and do not Sound Why this is?
Oversimplified, "clipping" is distortion. Clipping can damage speakers. You can reduce or eliminate clipping by reducing the amplifier's OUTPUT volume; or be reducing in the amplifier's INPUT signal. Excessive amounts of either can result in clipping.
Check out this video for a more in depth discussion about clipping. I hope this was helpful!
Aug 08, 2013 | Behringer Eurolive B212A Speaker
I installed a Q05-19700-00476 input PCBA for B215A componant. when I connect to the tweeter it blows it please help.
Certainly your hf driver is getting amp rail voltage, this is why tweeter blows, disconnect tweeter and with the unit powered on check the tweeter leads with a voltmeter and let me know the readings, but surely will be dc voltage...
Jan 02, 2013 | Behringer Eurolive B212A Speaker
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
Feb 09, 2010 | Behringer Eurolive B212A Speaker
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
Behringer Eurolive B212A Speaker Logo
338 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
