Question about HP Office Equipment & Supplies
Everytime i start the computer it pops up like 5 times in a row. I have the HPC4280 all-in-one
    Scholar:
  • 142 Answers
Don't worry about it.
The computer is just talking to it -- asking what model it is, etc. Because it's an all-in-one model, it might need to interrogate it about its various functions.
If it drives you nuts, then consider recycling it and getting something less annoying.
Posted on Feb 04, 2010
Every time I start my computer the Precision Scan folder pops up. How can I stop that from happening. I don't need want that to pop up each time.
Open "Run" type in there msconfig, then hit ok Go to startup tab and put check only to those programs you want to automatically run everytime you turn your computer on...
Jul 05, 2011 | Computers & Internet
The movie is running slow on full screen
check if the display driver is installed or not in your computer, here is the step to check the display driver is installed or not,
step 1. go to start and select control panel.
step 2. double click on system.
step 3. after this a window pop up select hardware.
step 4. click the device manager and after this another window pop up.
step 5. in this window you can display adapter on 4th row.
if you cant see this display adapter row so you can see something with ? sign in other rows and you can see vga adapter or display adapter down there. if you see ? sign that mean this driver is not loaded you need to load the driver for your display driver. there is no problem in your LCD monitor.
Thank you for using Fixya
Regards
Manish
Jun 10, 2010 | ViewSonic VX2240W-2 LCD Monitor
EMachines Desktop PC: Everytime I open a program on my desktop it will p...
download CCleaner HERE - [ upper right corner - says LATEST ] run it on each setting - 5 times - also - run the start up program - it will take you a little while - maybe a few days to figure it out but stay with it - and lose the cookies and check for a virus as well.
May 05, 2010 | E-Machines eMachines Desktop PC
Every time I change a cartridge in my HPC4280 printer, a window pops up on my monitor and says I need to do an alignment. Fine, but even though I tell it I already have an alignment sheet, it prints...
I believe that you are not completing the alignment process.
Let me explain the alignment process..
1- Remove the usb cable from printer and computer if connected through usb cable.
2- Turn off the printer, wait for 30 seconds, turn on the printer
3- It will print an alignment page
4- Place this page on scanner glass of printer from right hand corner
5- Press OK or SCAN button on printer
6- This will complete the alignment process.
It will not print an alignment page again and again.
Regards
Harpreet_351
Oct 11, 2009 | HP Digital Printers - Hewlett-Packard...
How to number a column. I can't remember the short formula, something like a1+1= which would make the number two pop up in the cell underneath.
You can number rows in a column by entering a number in cell A1 (usually the number 1 but youcan start with any number) and the formula (=A1+1) in the next row. The result there will be 2. Copy that formula down the rows you want to number and they will be numbered 3, 4, 5, etc. Each row adds 1 to the previous row so if you do anything that disrupts the sequence (like inserting a row between two others) you will have to copy the formulas down again to restore the sequence. You can also use the Edit-Fill-... menu command to put a series of numbers into rows. Put the starting number in th efirst row. Highlight it and the rows that you want to number and select Edit-Fill-Series... Those numbers will not change if you insert columns or move the formulas.
Or you can use the formula =ROW(A1) in any cell to return the number of that row. (The result of =ROW(A1) is the number 1 in cell A1, the result of =ROW(A2) is the number 2 in cell B2, etc. In this case inserting rows will not affect the numbering (i.e. row A5 will always be numbered 5 even if the data in it is moved down.)
Sep 18, 2009 | Microsoft Excel for PC
I have a 1998 dodge stratus and it blows the ignition fuse "sometmes" It might do it 3 or 4 starts in a row then work fine for a week. This makes it hard for me to diagnose. If it was the starter...
its not the starter has nothing to do with that area its a wire grounding out to metal or something grounding it look for a naked wire with black marks around it from popping
Aug 20, 2009 | Dodge Stratus Cars & Trucks
Acer Orbicam gone weird
uninstall your skype form add/remove
restart pc and then reinstall.
Then you need to set up cam with skype
tools options
video settings make sure you click to enable skype
start video automatically when in a call
if you need more help just let me know
Feb 12, 2009 | Acer Aspire 5100 Notebook
5 series' of 5 beeps in a row on start up
Check the Air Bag Indicator Light. When you turn the car on it should stay on for 6 seconds and then turn itself off. If a fault is detected in the system operation check, the indicator light will either fail to light, stay on continuously or flash. The flashing may not start until up to 30 seconds after the initial systems check.
If there is a fault in the system AND the air bag indicator light fails to light then an audible tone will alert you- it will be a set of 5 chimes (bells/beeps) five times in a row.
Have the Air Bag serviced and the indicator light bulb changed. Since the dash will be off in order to change the bulb, I would have all of the other dash lights changed at the same time. If one goes out, others will surely follow.
Corri R. / Service Writer
Jan 26, 2009 | 2002 Mazda Tribute
mukhtar21 shaikh
mukhtar21 shaikh
