Question about Jenn-Air JCD2290HES Side by Side Refrigerator
Ditto the previous 3 posts concerning Jenn-air model 2389. I have the same Jenn-air 2389, side-x-side 8-9 years (new) running cool (55*) on fridge side, but maintains ice (28*)on the other side. I will inspect and try solution offered by Eagle338 to determine if drain pipe is plugged. Any other solutions?
    Sergeant:
    Champion:
  • 263 Answers
Most likely adaptive defrost it out and it's covered in heavy frost in the back wall of the freezer. You fridge part 100% depends on the freezer.
Jenn-Air refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
MY JENN-AIR REFRIGERATOR #JCD2389GES IS NOT COOLING ON THE REFRIGERATOR SIDE. THE FREEZER IS OKAY. THE REFRIGERATOR TEMPERTURE IS 60 DEGREES F.
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Oct 30, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer coils icing up, refrig not cooling 8 years old expensive where is thermostat control
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
Jenn-Air JCB2389GRS Fridge not cooling properly
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer side works fine
you probably have a defrost issue. things to check are:
defrost heater not open circuit
there is often a thermal cutout in series with the heater and this may be open circuit.
defrost sensor may be wrong value.
fault in module
Jun 25, 2008 | Jenn-Air JCD2290HES Side by Side...
Fix it fridge
the compressor does not properly run ,motor valve weak ,test w/ amphere meter if does not match w/label amphere , comp. motor problem.
Dec 31, 2007 | Jenn-Air JCD2389G Side by Side...
Jenn-Air fridge not cooling
we had same problem with brand new refrig.
Serviceman just left - he replaced part  with label
"ADAPTIVE DEFROST ENCL.
61005988. I hope this works.
Aug 13, 2007 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
224 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
