Question about Convair Heating & Cooling
I have been given a used Supercool TRX How do I operate it?
I contacted the manufacturer.
Posted on Feb 06, 2010
How do i remove my fan from my 2004 honda 450 trx
I am not exactly familiar with this particular atv.. start with removing the gas tank, this should allow you to see where the fan is connected and bolted to. It should be a pretty straight forward operation.
Jul 01, 2017 | Honda 2004 TRX 450R
Fork oil capacity on yamaha trx 850
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha TRX 850 96
https://www.louis.de/en/rund-ums-motorrad/bike-datenbank/yamaha-trx-850/4un/0807
Yamaha TRX850H Service Manual
OEM parts for Yamaha
Yamaha TDM850 User Manual
Apr 12, 2013 | 1997 Yamaha TRX 850
My TRX has been layed up for 8 years. When hitting the start button, all that happens is series of clicks coming from the starter solenoid. The starter does not turn. Can you help. David Edwards
Hi David, I've heard this noise when my TRX has run out of gas on a couple of occasions. After refilling it and then pressing the starter 5 or 6 times with the gas tap on PRIME it has started. Leave about 15 seconds between each try on the starter button.
Sep 05, 2010 | 1997 Yamaha TRX 850
The rear pistons have seized on my trx 850. Is
I believe your rear brakes are mechanical though they could be hydraulic. This is not an easy repair, which ever method is used. It requires first and foremost, some way to hold up your bile while you remove the tire. Then you must remove the tire and drive train as well as other items ...
After the problem is repaired, there is reassembly and adjustment. Complicating the matter is possible corrosion on other parts of this 13 year old motorcycle.
My advice is for you to contract with your local Yamaha shop for this repair.
Mar 09, 2010 | 1997 Yamaha TRX 850
I HAVE A YAMAHA TRX 850 AND IT HAS STARTED TO RUN LUMPY THE PLUGS HAVE BEEN CHANGED USEING A BIT MORE PETRAL THEN USEAL . ALL SO IT FEEL LIKE IT HOLDEN BACK AND HAS A **** MISS FIRE
I would say you probably have a problem with one or more carbs. The carbs should be cleaned and vacuum balanced. Make sure you don't have a vacuum leak to start with.
Jordan
Oct 02, 2009 | 1997 Yamaha TRX 850
What the X in TRX?
it stands for CROSS meaning it can go on road or trail
Cheers Rob
Sep 19, 2009 | 1973 Triumph TRX 75 Hurricane
Have goodman unit, ac unit running 55 suction, 210 high side. cleaned condenser coils and charge to 10 degrees supercool. suction at 65, discharge 245, why did my discharge go so high
You should have liquid line filter/dryer that maybe restricted or there is a restriction in the orfice inside the evap coil normal operating pressures are 68/ 180
Oct 07, 2008 | Goodman Heating & Cooling
MOTOROLA WIRELESS BROADBAND ROUTER 850G
Yeah that WR850_6.1.4.trx is the one that you need to install. That's a firmware for your router. You need to login to the Setup Page of the router then look for Firmware Upgrade category. It will then ask you to browse for WR850_6.1.4.trx file then hit upgrade.
Aug 20, 2008 | Arris Wireless G Broadband Router (wr850g)
Heating & Cooling Logo
129 people viewed this question
Top Convair Heating & Cooling Experts
Pete Norton
David Payne
David Payne
richie46
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
