Question about Cooktops
We have a Jenn Air cooktop model C203 (about 20 years old). The "insert" (additional 2 burners on the left side where the grill / griddle would otherwise be) seems to not always work properly. That is, when you turn it on, sometimes they don't get hot until you "jiggle" the connection where the insert plugs in. I assume there's a loose connection. Thoughts?
  • Cooktops Master
  • 8,220 Answers
You could yank the drop in module out and clean the contacts. The receptacle can be replaced.
Posted on Feb 04, 2010
Testimonial: "Very helpful"
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Cooktops Logo
200 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
