Question about York Barbell Home Use Fold-Up Treadmill
It has stopped and smells like a motor is burning comes up with error 1 Its a york Barbell treadmill and is model number T-406 LA
  • outfield502
    outfield502 May 11, 2010
    Good start I will say that you should send your motor for re-winding it because when too hot, can damage the card that controls the same engine
  • 79 Answers
Ok! how I say, just send your motor DC to repair, at the same time, check the engine controller. any diode or mosfet is bad or damage
Posted on Feb 05, 2010
Treadmill not working
Belt speed Loss:
This condition indicates that the speed pickup signal was lost continuosly by during 1 second after the motor successfuly started.Normally indicate a failure of speed pickup or abrupt belt stoppage to due any motor, wiring,or motor controller failure.
Oct 24, 2011 | York Barbell Home Use Fold-Up Treadmill
I have a York evolution tv treadmill model x8 which starts for about 3 seconds then stops with E7 on the display, I understand this is a safety key error code but the key is in place and if it's...
Definition: Incline motor calibration abnormality: 35~40 seconds after the down command was sent,
the calibration base signal was not received.
Check the calibration motor (mechanical +electrical)
Jul 11, 2011 | York Barbell Home Use Fold-Up Treadmill
Hi my treadmill starts and then stops and comes up with E1
Motor does not operate; Display CPU cannot read the optic sensor signal.
Check it and adjut the Reed swicht and optical Sensor
Jul 02, 2011 | York Barbell Home Use Fold-Up Treadmill
I lost my manual for the York Pacer 3100, where can I download the manual? I also need to replace the running mat but I don't know the part number.
Try this 3 web page:
1) Free. http://fitness.manualsonline.com
2) Pay:www.fitnessrepairparts.com
3) Pay: http://manualsfactory.com
e.cuadra
May 24, 2011 | York Barbell Home Use Fold-Up Treadmill
Hi just wondering if anyone can help with a problem with my York T500 treadmill. It comes up with error 03 in the speed panel. Any help would be appreciated. Thanks
hi,
Error E3 means speed sensor error.there is a sensor for checking and controlling the speed. check the speed sensor and its,connectors, clean the speed sensor. for that u have to open the motor cover.
ok
Dec 30, 2010 | York Barbell Home Use Fold-Up Treadmill
My York t302 threadmill motor starts to keep strange noise after some running. Motor has been changed once as well as whole threadmill. So this is my third motor and problem still exist. Here is the...
i just had a noise in my York T301 that sounds exactly the same as yours. It also came up with a E1 error code and stopped working. I pulled the motor hood off and noticed that the magnet in the drive pully had come dislodged. It was hitting the speed sensor near the belt. Glued magnet back in and all better. Hope this helps.
Oct 06, 2010 | York Barbell Home Use Fold-Up Treadmill
ERROR 7
Sounds like a incline problem , could be that the incline motor is stuck or the fuse may have blown on lower electronics.Call or E Mail:
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Apr 25, 2010 | York Barbell Home Use Fold-Up Treadmill
Where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Apr 11, 2010 | York Barbell Home Use Fold-Up Treadmill
Hi, have lost the manual for my treadmill York T500 treadmill. Error 7 keeps coming up...what does this mean please?
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Apr 20, 2009 | York Barbell Home Use Fold-Up Treadmill
York t500 treadmill model no:LQ6010 showing err07 when turned on
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
York Barbell  Home Use Fold-Up Treadmill Logo
411 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
