Question about LG LFX25960ST Stainless Steel French Door Refrigerator
WHEN WE TURN ICE MAKER ON ERROR CODE er f - LG LFX25960ST Stainless Steel French Door Refrigerator
  • 1314 Answers
SOURCE: Kenmore Elite Trio
pull the kickplate or look on the back of the unit in the compressor comparment some where on that unit is a tech sheet that will explain that code i dont have access to kenmore tech data as sears tends to keep a pretty good lid on it but if you find the sheet and reply i can help
Posted on Jan 19, 2008
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
SOURCE: error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
if "er if" means = ice fan, then whats changing the board gotta do with it? shouldnt the fan be changed?
Posted on Oct 09, 2008
peyton32034
  • 410 Answers
SOURCE: I have error code ER dH. Unplug and then replug
er dh means the refrigs computer is not sensing a defrost cycle (dh means defrost heater) most common problem is a bad defrost sensor located on the evaporator behind  the plastic cover in the back of the freezer compartment. your refrig will continue to cool for about 1 week unless you get this fixed then the evaporator coil will ice over and have to be defrosted manually.
this is an easy part to replace yourself and you can purchase the part thru sears.com or any of the other parts distributors on the net. you will need a complete model number from the unit to be sure and secure the correct part.
Thanks for using FixYa peyton...
Posted on Feb 18, 2009
  • 30 Answers
SOURCE: LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Posted on Apr 22, 2010
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
I saw a word in the front is ER CF like error
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
CLICK
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Oct 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We get no water or ice from control panel. On panel it says Er iF. What does that mean and how can we fix it. We have tried resetting the power and it goes back for a second then returns to Er iF.
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
Jan 29, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
I have an error code er if on my Kenmore Bottom Drawer Freezer 79577573600. Everything works except the ice maker. Is this a part that can be easily replaced or should I go ahead with the service call I...
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
Er if code on display
ER means Error code......
The If error message indicates that the fan for the ice maker has failed. The main control board receives a feedback signal from this fan motor for the ice maker. If the feedback signal is abnormal or missing, then the error message will be displayed. The fan motor for the ice maker could be bad. You could also have a bad wiring connection between the motor and the control board. A remote possibility would be that the control board is bad. This is not likely since you noticed the ice melting in your storage bucket.
I recommend calling a service technician to diagnose and repair this failure.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite bottom freezer unit displays an "er IF" message and water is leaking from the ice maker door. what does this mean? the manual doesn't help
Jun 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MY ICE MAKER WON'T WORK
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
37 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
