Question about Maxtor Hard Drive
Maxtor external back
Can't remeber how o run my maxtor external back
  • Freida Newsome
    Freida Newsome Feb 21, 2008
    How do you get the files from the "C" Drive to the External Drive? And if you do get them over there...Do you delete the files from the "C" Drive?
    Genius:
  • 1,019 Answers
plug in your external drive, and note it,s letter ( assigned device name ) i.e F/G/H et,c.
open your c:/ drive. highlight which items you want to copy over.
left click to highlight. then right click/Options/scroll Down Send to DriveF/G/H
And transfer, this should transfer what you want from 1 drive to another. But Don,t try to copy Windows. you.ll have errors as some of the sys files, will be in use whilst transfering.
mike @ compurepair.
Posted on Feb 23, 2008
How to take the outer casing off a maxtor one touch external hard drive
  • Feel along the back and bottom side of your Maxtor external hard drive. Depending on the specific model of hard drive you have the unit may have screws or plastic latches inside the case. Pull of the warranty sticker and check to see if the screws are located underneath it if you don't see any screws anywhere else. Pull out the rubber stoppers at the bottom of the external hard drive case and check if the screws are located underneath. Remove the screws if your model of Maxtor external hard drive has them. Insert a thin and flat object such as a flat head screwdriver between the seams of the two sides of the case if there are no visible screws. Run the flat object around the length of the external hard drive case until it hits a plastic latch. Wiggle the object up and down until the latch disengages. Continue sliding the screwdriver along the sides until all the latches are disengaged. Pull the two sides of the Maxtor external hard drive case apart to reveal the actual hard drive enclosure inside. Remove the screws holding the hard drive into its metal cage. Pull the existing hard drive unit out the metal cage and replace it with the new hard drive. Reassemble the unit and plug it back into your computer.
Oct 27, 2010 | Computers & Internet
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
External HDD is not working
You probably have conficker worm because it stops your pc from reading usb's or any external HDD. Or the worm might of infected your HDD since it spreads through usb and internet. Seriously you should get your PC scanned just incase. P.S. Its just a possibility.
Jun 09, 2009 | Maxtor Hard Drive
MAXTOR EXTERNAL HD IS NOT OPENING
Does it give you an error message ? Are you running Windows XP or Vista? If so post it here so the problem can be further narrowed down.
You might want to try a chkdsk.
In Windows XP and Vista both, a shortcut to get to the command console is holding the Windows Key and pressing R.
in the command console, type:
chkdsk X: /f /r
Where X is the drive letter of the drive giving you problems.
This will run a chkdsk on your external, restoring files and folders that cannot be accessed.
I also have a Maxtor External hard drive and have to do this quite often. It's pretty frustrating.
Apr 04, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
Maxtor basics external drive
Hi Nuisance101, I recall your running vista. Vista is a nightmare. If you cound only see the troubles we see on a daily basis here at FixYa you'ed understand. It's a common problem with Vista not seeing USB devices, externial devices. It does & then the next second it doesn't. Same for all external devices. I'm am 100% sure the trouble is not your system or your devices. It's Vista. I have gone over dozens of post from vista users. One would think MS has been on vacation since the release of vista. You can look at vista's web site for help for a possible fix, at this link. (I have no faith). MS blames driver software. Your Maxtor drive is external. Henve no driver software.
So it falls into that vista area of one time vista see's the drive & the next it does not.
Either way I though Maxtor addressed vista issues. I prefer Seagate drives myself. Personally know lots of people who's Maxtor's drives have just gone down for no reason. Seagate bought Maxtor.
http://windowshelp.microsoft.com/Windows/en-US/hardware.mspx
Most of the post from vista users, claim users should check vista's updates often. Since Max Blaster did its job, I'm inclined to blame vista.
I wish I could give you a better fix or suggestion but I'm up against vista. That's why I run WinXP Pro. I do not have these problems.
Best wishes Nuisance101!
Mike
Mar 30, 2008 | Computers & Internet
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Maxtor Hard Drive Logo
71 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
