Question about Canon PowerShot SD1100 IS Digital Camera
My lens doesnt move in to close
It just suddenly stock up but functions are good.only the lense it doesnt come in and out
2 Suggested Answers
  • 11967 Answers
SOURCE: it seems the lens is stock. it was working just
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 14, 2009
What lense can i use for close-up shots
That would depend on the camera, but I'm going to assume you have one with interchangeable lenses.
The camera manufacturer probably makes one or more "macro" or "close-up" lenses for your camera. Any of these lenses will let you get closer than a normal lens. Many third-party lens makers also make macro lenses.
Another alternative is to put extension tubes between the lens and the camera body. This moves the lens further from the camera, shortening the focus distance.
Probably the cheapest (and lowest quality) alternative is to put close-up lenses on the front of any lenses you already own. These screw on to the front of the lens like a filter and act like a magnifying lens, letting you get closer to the subject.
Sep 07, 2013 | Computers & Internet
My lenses on my Von Zipper sunglasses are scratched from a car accident I had. Am I able to get them repaired by Von Zipper company
The Sunglass fix have most models in stock, (30,000 styles) ready to ship, and will custom cut if not already available. http://www.thesunglassfix.com Von Zipper Replacement Lenses Award Winning Lenses for USA Sunglass...
Aug 16, 2012 | Von Zipper Clothing Accessories
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Just bought the Olympus pen EP-L1 Im having trouble find lenses for my new toy any suggestions?
You don't state why you're having trouble finding the correct lenses, but they are easily available from online suppliers. Traditional retail outlets tend to stock very few of them though simply because there isn't sufficient demand to buy in and keep stocks of products which are constantly having updates and price adjustments.
You can use all Olympus Micro Four-Thirds lenses and most Panasonic Micro Four-Thirds (although to use some of the latter you may need to update the body or lens firmware.
Regular Four-Thirds mount lenses can also be used via an adapter but may not be fully functional.
Unlike other lens mounting systems, you can also get adapters to use almost any lens on Micro Four-Thirds system cameras, but the lens will typically have to be used in a fully manual mode with the aperture set fully open for composition and focus and then manually stopped down for metering and image capture.
Jul 12, 2011 | Cameras
Broken lense to police sunglasses. These glasses are approx. 12-15 years old but are much loved. Mod Police 2346 Col 647
As there is obviously no warranty any more, the only way is to see a good optician, best one who is selling police, and have both glasses replaced. It's impossible to replace only one because the optical lenses are now technically much more advanced as well as the colors. Whether it's worth the time and the expenditure for these old glasses you will have to decide after getting an estimate of cost for the new lenses and repIR
Apr 30, 2011 | Police Clothing Accessories
How to replace the lenses for oakley spike
I did the following... step by step, if you have any questions, please ask. - I placed the sunglasses perpendicular to me. One if the lenses will be close to you, while the other should be farther away.
-I grabbed the farthest lens from your body with both hands. Placing your left had on the left side and your right and on the right side. One had is on the bottom of the lens, while the other is on the top of the lens. It does not matter which hand is on the bottom or top.
-I grabbed the top and bottom of the frame, pulling away from the lens. At the same time I pushed with my fingers (that should be on the inside of the lenses) and pressed the lens out (on the lens closest to the nose pieces). You will hear a very faint "pop" when the lens clears the frame.
-Then slide the lens out by grabbing the part that is out of the frame that is close to the nose piece
-To put the new ones in, position the sunglasses the same way and put the replacement lens in the sunglasses, starting with the edge near the ear pieces.
-Pull the top and bottom of the frame out and push the replacement lens into place.
If you have any questions, please ask. If I can clarify anywhere, let me know.
Good luck.
And once you do this,could you please leave me feedback and vote on my answer?
Thank you very much,
Lori
Mar 17, 2011 | Oakley Spike Sunglasses
Camera filter stuck on lenses
You can try using one of those rubber jar openers, if you have one handy in your kitchen. Or wrap a suitable size rubber band around the filter to improve traction.
If that doesn't do it, a good camera store should have a filter wrench for exactly this purpose. If you don't want to buy one, simply ask for a demonstration of the product, using your lens. Most clerks will be happy to remove one or two filters. If you bring in a large box of lenses...
Jul 12, 2010 | Canon Cameras
Canon PowerShot SD1100 IS Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
