Question about Compaq Presario 5000 PC Desktop
I installed system mechanic professional and hit the drive scrubber button and wiped out my hard drive completely. i tried to install widows vista and i it won't allow it to install. i get a file error (0xe0000 100) and (0x773442eb) what does this mean and how can i fix the problem
    Problem Solver:
  • 6 Answers
In that case it affects the file system of your hard drive that's why it fails the windows vista installation. In order to fix it you need to delete the partition of your hard drive and create a new one using a partition manager software.
If you can connect your hard drive into another computer you can perform a disk partition using the Disk Management (In Windows XP: Control Panel > Administrative Tools > Computer Management > Storage > Disk Management)
To help you with the procedure on "How to use Disk Management."
http://support.microsoft.com/kb/309000
Using Disk Management, after creating a partition in your drive, proceed to formatting.
Posted on Feb 05, 2010
How to get ride of my old operating system
YOU NEED TO UNISTALL BOTH OPERATING SYSTEMS COMPLETELY THEN REINSTALL VISTA.DOWNLOAD WINDOWS VISTA AND SAVE IT FIRST..AFTER UNINSTALL,GO TO YOUR DOWNLODS ANR RUN WINDOWS VIST TO INSTALL.
Jun 03, 2012 | Microsoft Windows XP Home Edition English...
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
How to format the system?
You can completely wipe out your system by employing DBAN ( http://www.dban.org/ ) - *CAREFUL*, there is no undoing this format! Backup any important data on an external drive or unit.
Once formatted, you can reinstall your system using any OS CD/DVD (by preference, those which came with the system).
If what you're doing is trying to recover a broken OS, you may try a "recovery install" from the OS CD/DVDs before resorting to a complete format.
May 18, 2010 | Microsoft Office Professional 2007 Full...
Black screen on Vista reinstall
make sure you have only one video card installed check bios for the video card.. try vga..if expansion video card is installed...remove it and use the internal to check if it works..
Dec 30, 2009 | Microsoft Computers & Internet
Windows vista installation
If you purchased it new, you can probably get a recovery disk from HP.  HP usually puts a recovery partition on one part of the disk, but if your utility program wiped that out, then you will need help from HP directly.
You can try HP's website by starting here: http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=pavilion+dv6000&submit=Go+%BB
The following discusses ordering a recovery disk: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810334&lc=en&dlc=en&cc=us&product=1842155&rule=21883&lang=en
If the recovery parition is still intact, you might be able to recover based on this link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=21883&product=1842155&docname=c00809678#RecoverOS
Restore the PC to its original condition with the HP Recovery Manager if Windows Vista is not accessible If the PC cannot launch into Windows, it may still be possible to use the HP Recovery Manager on the hard drive to restore the computer to its original operating condition by first pressing the Power button to start the PC, and then pressing the F11 key to start the HP Recovery Manager. NOTE: Depending on the BIOS version, your computer may display multiple prompts during startup including F11 to start System Recovery. Pressing the F11 key on a computer with an HP factory image will start System Recovery even if the prompt is not displayed.
  • If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before beginning the recovery. Follow any on-screen instructions.
  • If the HP Recovery Manager cannot access the hard drive to fix any system errors, use the set of recovery discs to recover the hard drive to its original condition.
Apr 25, 2009 | Microsoft Office Professional 2007 Full...
Tryed replacing vista but it cant find my hard drive
If you are attempting to use your "System Recovery" or "System Restore" disk it is likely that the portion(s) of your hard drive containing files that this process may require have been erased.
In this case you only have a few options:
  • Contact your manufacture and attempt to get a full install cd, which is often very unsucessful, but it depends on your manufacture.
  • Contact Microsoft, let them know your situation and state that you have a Product Key and require a install cd. This to is not usually sucessful but its cheaper then the last option.
  • Lastly, you can purchase Vista, or any version of Widows you wish to install on your machine.
I hope this has been of some help.
Let us know if you run into any bumps.
Good luck.
P.S.: Product Key is generally located on a tag on the side of your desktop/bottom of your laptop, or in the documentation that came with it.
Apr 15, 2009 | Computers & Internet
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Installing Windows XP alongside Vista
First you want to install xp and then only you want install vista because higher version will not take lower version.
Feb 26, 2008 | Microsoft Windows XP Professional for PC
Compaq Presario 5000 PC Desktop Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
