Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Right door can not be opened --how to unjam it
  • victoria cooke Feb 07, 2010
    thank you --- we took apart the entire machine to get it open finding a metal guide had been jammed up
  • 542 Answers
As the door lock has been jammed so you are facing this problem. Don't try to open the same forcibly as it will damage the cover as well as lock. Need to check and service the same with the help of local expert engineers or service center experts.
Revert back for more assistance.
Posted on Feb 07, 2010
1992 isuzu trooper LS right front passenger door wont open with key and inside the button wont rdlease
locks jammed , remove door card skins,and unjam it
is lock frozen with ice,
its 86f here, nice
but we cant see you ,car or where you are at.
Feb 11, 2017 | 1992 Isuzu Trooper
Left front door wont open from the inside
the spring in latch has broken and it wont open door try put key in lock outside and lock unlock while opening the door sometimes unjams to be able to open door without taking panel off inside with door closed if dosnt work you have to remove the panel inside replace door latch assembly
Apr 04, 2014 | 2007 Kia Sportage 4x4 V6
How to get the back doors unjammed in my 1995 honda passport.
Jammed, like in you pull the handles and they won't open?
Well they do have these child safety lockouts where you can't open them from inside, you have to open them from outside then flick the latch on the door. That is if I read your problem correctly.
Mar 02, 2012 | 1995 Honda Passport
I have 2004 Toyota 4Runner - Hatchback Someone Slammed the Hatchback door and now is jammed. How can I unjam this to Open
push down hard on the door as you try and open it,, once opened you will have to align the clasp end of it,, it was probably loose and moved when slammed
Apr 29, 2011 | 2000 Toyota 4Runner
My 944 photo printer says its jammed, how do i unjam it i've never used it and just took it out of packing box, how do i unjam it.
open all doors on the printer and look for any "orange colored" tabs of plastic and remove them. Your ink cartridges could also have things on them. But I would just look in the covers and see if you missed and orange plastic or tape.
Best of luck..
Nov 19, 2010 | Dell 946 All-In-One InkJet Printer
When you move the controls in the heat position you have no heat but a thumping sound up under the dash
your blend door is not actuating. The door may be jammed or the actuator gears may be slipping. Remove the actuator and check the door for free operation. If the door is jammed, you may need to open the heater box to unjam. If it is free, replace the actuator.
It looks like the actuator is right on the front of your heater box--see diagram below.4ad64fe.gif
Oct 03, 2010 | 2001 Ford Windstar
My driver side sliding door handle broke off. I had locked all the doors since and the lock is jammed. It won't go unlock so I can open it. Really my question is in two parts. How do I get my door unjammed...
open the front door...
now you have to push the locking rod towards the rear so you can open the sliding door from the inside
just follow the B pillar down and use the passenger side as reference of that black rod
Feb 10, 2010 | 2002 Nissan Quest
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
Mar 30, 2009 | Whirlpool AWM8163 Front Load Washer
How to change toners
Open front door, check on the color facing you, close door, press the color cartridge to advance the carousel to the color you need to replace, pull out the cartridge and replace with new one.
Jan 13, 2009 | HP Color LaserJet 2550n printer + HP Color...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
