Question about Fantom Drives Titanium II (TFD160U2) 160 GB USB 2.0 Hard Drive
We have a Comstar 640gb external Hard Drive. All tests say drive is healthy. Running Windows XP. Drive was working yesterday when hooked up to our old PC. Now on new PC Windows will see the HD and we can see the files on HD but we cannot open or move files. We are using the correct USB port. Any suggestions?
Can I ask a question about this Comstar 640gb external Hard Drive? What kind of power adapter for this external Hard
Drive? How many volts? I lost my power adapter for this hard drive while moving.
Steven
Posted on Dec 04, 2010
Files from a back up
You should be able to plug the external hard drive into the new computer and restore. Generally the drivers needed to access the external driver are on the external drive itself. The operating system will detect the hard drive (if it has plug-and-play services running). If the new computer fails to see the external drive, check the cable and download the driver manually from the manufacture's website. If the drive is recognized by the operating system, but you do not see a prompt to restore from the backup, you may need to locate a setup program on the external hard drive to start the restore process.
Apr 18, 2014 | Computers & Internet
Window command to format HDD H551 portable.
If you are connect it with a windows 7 it ask you reformat your hard drive. But if you work in a windows Xp it will work fine and no need to reformat.
Jul 19, 2011 | PQI H551 640GB 2.5" USB 2.0 Portable...
Every since I have upgraded from XP to Win 7 I cannot get my toshiba 640gb external hard drive to work. It registers an icon and it does pop up under the list of hard ware and devices but, I am unable to...
Did you check the Microsoft Hardware list before you did this upgrade?
If not, please check it now ... at ... http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your device is listed ... great .. you have a solvable problem. If not listed, you will have to upgrace your hardware.
Sep 16, 2010 | Toshiba 640GB USB 20 Portable External...
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Trying to read external HD, unknown partition
I see that you have a loss partition of your External HD. It is totally damage partition.
Here's what you do Replug your External HD to another PC if it is OK. Maybe its not the same will appear on your PC too.
Unknown Partition are likely big trouble to us if we have needed files inside.
Partition on every HD, External or USB are very needed, if you lose it. Then again reformat that to use again.
Hope its not gone. Good luck!
Aug 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Format external hard drive to NFTS
Assuming you are running Windows XP or Vista, the easiest is through the Disk Manager.
Open the administrative tools from the Start menu and select Computer Management. Then select Disk Management in the console.
Now you can right-click the disk and select Format. Chose NTFS and wait for it to finish (which will take some time!).
Do realize that this will erase your data on the disk. If you do not want that, you need to use the CONVERT command from the command prompt. type CONVERT /? to find out about its usage.
Jules
Apr 04, 2009 | Western Digital Elements powered by WD 320...
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
I have a SimpleTech 250 GB external hard drive and would like to transfer the data from the hard drive onto my new HP laptop which is running on Windows Vista. However, when I try to sync, the name of my...
U can remove the drive from the external unit and hook it up to your vista computer as a secondary drive. Boot up the vista, use windows explorer, and transfer the data from the secondary drive to either your primary or a usb stick.
Jun 25, 2017 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Fantom Drives Titanium II (TFD160U2) 160 GB USB 2.0 Hard Drive Logo
283 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
