Question about Car Audio & Video
Hi i have a ripspeed dv710 plays the radio fine put a cd in and theres no sound but timer goes up si a no its plying same on dvds you can watch the film but no sound anybody help??
  • Paul Clements
    Paul Clements Mar 15, 2010
    I have a similar problem and believe it to be a fault with the unit itself. The radio works fine so it is not an amp issue at all. the dvd drive has a ribbon cable which attaches to the main board. to prove the point where the possible damage was I took the cable out and turned it around as it is the same both sides,. when I switched the unit back on I had a different fault indicating the ribbon cable was defective. Up to now I havent been able to source a replacement but even the new cable would foul on the mounting bracket inside and fail eventually.
  • Anonymous Mar 31, 2014
    There is no obvious reason why I can't wire this in but I may need a clue , as I'm stuck does it need a special earth or something , and as for fuses there arnt any ??????
    Sergeant:
  • 306 Answers
It sounds like it was installed incorrectly. there must be amps in the car. when the dvd player was installed they hook up a blue wire on the back of the radio. its a power antenna wire . switch it for the blue white wire and youll be in buisness
Posted on Feb 06, 2010
I want to burn mp3's on a DVD, to play on my ripspeed DV710. Tried a couple of programs but I cant get it to work. Can anyone help?
just place the MP3 directly no folder then ,any program should do it but the DVD and/or CD you are using must be finalised when you burn them.
You should see a n option di do that in your program
Nov 02, 2014 | Office Equipment & Supplies
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
Hi ive got an 12VCITY MA-7004 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i
hi, i bought <a href="http://www.12vcity.com/wholesale-car-electronics-car-dvd-2-din-car-dvd/13-car-double-din-dvd-player-buy-car-double-din-dvd-player-ma-dvd7004.html">12VCITY MA-7004</a> on 12VCITY official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.I think maybe you have connect the wrong wire and have bum out the built in amp.
Jan 11, 2012 | Car Audio & Video
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
Nov 08, 2009 | XO Vision XO9013 Car DVD Player
Radio works but cd plays with no sound
you probably have your amp hooked up to your power antenna remote. there should be another blue wire (probably blue with a white stripe) that is for amp remote.
Sep 09, 2009 | Eclipse 5442 CD Player
DVD-player won't play DVDs, but reads CD/DVDs for programs fine..
Could be a codec problem, try downloading the codecs from codecs.com
download the codec pack for your OS.
Jun 26, 2009 | Computers & Internet
CD multichanger not playing or working.
I havena't done anything much except to take all the cd's out and have put in the 1st which always worked fine. Then I put in a 2nd and at first it did not want to work. It sounded like a cell phone breaking up. I turned it off completely. And this a.m. both are doing fine. I will try the 3rd and 4th a little later today and hopefully they will work.
Dec 07, 2008 | Bose Wave Radio
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Sound cuts out
If you listen to cd's and the sound dos'ent cut out then it cant be the amp. It could be the audio cables are intermittant between the amp and the dvd playerr or they are loose or corroded a little. or ppossible the input your using is going bad on the stereo sytem but I wouldnt think that the whole system was blown if the radio and the cd plays normal.. check out the causes I listed and let us know if you need more assistance\..:)
Apr 19, 2006 | Technics SCEH790 CD Shelf System
Car Audio & Video Logo
590 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
