Question about Canon MX700 Office All-In-One InkJet Printer
Mx 700 returns error 5100 message: Mac OS 10.5.8
How can I repare fault 5100???
Posted on Feb 09, 2010
I am trying to hook up a Canon MX 310 to my MAC and tried to download the driver and end up with an error message. Failed many times and just can't figure it out...can you help?
Depending on which Mac OS you are running you shouldn't need to download a driver - most Canon printers are included in the Apple software from X10.5
Jun 27, 2011 | Canon PIXMA MX310 All-In-One Printer
I am using canon mx 328 printer. it shows error occured 5100
remove cartridges. clean the contact surface of the cartridge where the contact terminal inside the printer touches. You can use a cotton moistened with alcohol. After that return the cartridges and restart the printer.
If different errors appear, try to reset
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
If another errors appear, try to press the STOP/RESET button for at least 5 seconds and wait until the printer self restart.
I hope that helps. Just post back when you still have questions.
Please rate this answer and leave some testimonial too.
Thank you for using Fixya.
Oct 30, 2010 | Canon PIXMA MX310 All-In-One Printer
CANON MX 700 CODE 5100 TRIED EVERYTHING
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Canon MX700 Office All-In-One InkJet...
HP 5150 loses connectivity every couple of days.I get a message that says the printer has lost its connection. All cables are good. I have the identical printer at another location and when it is used...
I do not know which driver you are using since three different Ones are listed  8,9, and OS-X. I f you are not using OS X  or at least 9, I would consider trying them , if I were you,since you are currently using 10. The driver page states that if you OS in not listed. then they do not recoment this printer,in so many words.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=304431〈=en&
Feb 12, 2009 | HP DeskJet 5150 InkJet Printer
EMac G4 700 512
try to download adobe flash player installer for MAC..
Jan 31, 2009 | Apple eMac G4 Desktop
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Ml-1510-700 install for mac 10.4
Download the file ML-1510 Mac OS 10.2.4 or higher, Mac OS 10.4~10.5 (ver.0.97) from the Samsung Download Center (http://www.samsung.com/download/#)
The file is called "
20040714091617593_SPL2.dmg". Then look for the driver called ML-1510 -700 (N.B. not Samsung ML-...)
Jan 17, 2008 | Samsung ML 1510 Laser Printer
Canon MX700 Office All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
