Question about Samsung PCL545R 54" Rear Projection Television
Samsung PCL545R 54
Posted by EMELY on Feb 17, 2008 Report abuse
Timer light continuous blink -- Did "hard reset" (24 hrs unplugged) problem continues. Thanks .
    Genius:
  • 3,587 Answers
Hmmm...that's fine...but does this unit have a warranty?
Posted on Feb 20, 2008
Mitsubishi HDTV Won't turn on
wow...that seems like a firmware or control board issue. Did you have a power glitch recently? May need a service call, is it under warranty?
Feb 17, 2008 | Samsung PCL545R 54" Rear Projection...
Why does the LED light continually blink and not go in to standby mode?
Continuous blinks of standby LED indicates a main board fault. Just check this set after a reset. If it do not help you, replace the main board.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Can't find link: "Report Abuse"
Put the http address in your restricted addresses in control panel under internet optons.
Aug 28, 2009 | Computers & Internet
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
The stand by timer blinks continuously
Unpluggnig the set will reset some things, but not an error code. The 4 blinks usually means a lack of vertical deflection. If you can solder, you should be able to fix this yourself. Be warned however that there are dangerous high voltages inside the set even when unplugged.
That being said, try locating the vertical IC which will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. Try resoldering the pins on that IC first. If that failes to resolve the problem, replace the IC and post your results here. There may be other components that need to be replaced, but they will show up as other symptoms once the IC is replaced.
Dan
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Sorry did not know if I posted this correctly or not.
I just brought my kf-42we610 sony authorized service-tv went black would not turn on-I was infromed Sony knows about problem with the fan in back -gets way to hot and basically melts everything-they are fixing free of charge until march of 09
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
Samsung PCL545R 54" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
