Question about Sony VAIO VGN-N130G/W Notebook
Wireless Network stopped detecting ALL local networks
My Sony Vaio VGN-130G laptop won't detect ANY WiFi ports. It worked great 2 days ago and now it won't detect any wireless networks when the computer was turned back on. Reformated the laptop back to the orignal configuration ....so I know it isn't a software problem. Called Sony tech support and they want $279 plus shipping and taxes to fix. The computer is ONLY 14 months old....just out of warrantee.
  • MrHueyD Apr 29, 2008
    Same thing happened to all three computers in my house. Failures were staggered, so it's not the router. Happened just after an MS update.
  • Rose22 Jun 30, 2008
    my laptop is picking up the wireless connection just fine. Except for when I try to access email, internet, etc...it will not connect. My wireless connections says 'excellent'. I've also used ethernet connection. I've also tested this at both home and work to rule out the router. So, it is not wireless adapter right?? because it is picking up the connection, ...it is not router because I tested more than one...what is it? When I went to firewall settings and clicked on advanced it say my network connection was corrupted. When I diagnose the problem it says there is a problem with my Winsock?? Please help.
  • 77 Answers
Hi, Have you installed the driver for your wireless card since you re-formatted?
Right click on my computer and go to properties, select device manager. all of your hardware will be listed there. are there any yellow question marks? these are devices that need drivers.
Your wifi card will probably be called 'network adapter'. go to the sony vaio website and download the right driver for your wifi card
Posted on Feb 20, 2008
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 08, 2008
Try turning on the wifi switch Fn + F7
I have a sony va10 vgn-f j270/b notebook.it has ethernet from an intellinet router. however it has no wifi connection.the control panel there is a red x with the 2 computer symbols with the statement
Have you checked to ensure the WiFi switch is turned on? The computer with the red X is typically to let you know that connection is off (or in the case of the port that there is no hardline). Basically the 2 computer are one hardline, one wifi. Make sure the WiFi switch is on. It is usually a physical switch on the front for Sony laptops.
Nov 16, 2013 | Sony VAIO VGN-N130G/W Notebook
Wifi not working on my sony vaio vgn-nw270f
make sure you turn the wireless switch on. It should be on either side or the front of the laptop.
Did you configure the new router and set the wireless on it?
If your internet provider is a phone company such as AT&T did you configure the router to be PPOE (and set the userid and password) and bridged the modem that goes into the router?
If your internet provider is a cable company did you set the router to be DHCP?
Does the Sony even see the wireless network in the View Available Wireless Networks list?
Did you put the wireless key in correctly?
You didn't by chance happen to hit the FN function key on the lower left portion of the keyboard + the key (F1 thru F12) that toggles the wireless on and off? The correct F1 thru F12 key to hit will have the wireless signal icon )))) or it will have the icon of a tower with the wireless signal )))).
Apr 25, 2012 | Sony VAIO VGN-NW270F/B Notebook
I have a Sony VAIO VGN-NR260E here that persistently toggles the wireless off. The wifi switch on the front of the computer is ON but no light appears. There is no wireless on/off shortcut on the keyboard.
You should try one thing
Go to control panel - than go to network sharing - than try wireless local area conection to enable & than try it
thannks
Jan 03, 2011 | Sony VAIO PCG-K25 Notebook
I want to get all my sony vaio vgn-s590b driver program because i cant get wifi signal n lan for the internet'
Unfortunately, the Wireless card in the VAIO model VGN-S580B does not support n standard. The integrated Intel PRO/Wireless 2200BG Network Connection Driver supports IEEE 802.11b and IEEE 802.11g standards. It is require to use an external Wireless card to use the n standard.
However, here is the link to download all the drivers for your computer model:
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=VGNS580B&LOC=3
Thanks
Jan 03, 2011 | Sony VAIO VGN-S580B (VGNS580B03) PC...
Wireless network on sony vaio
Sir,
check the links below and go through the sites......u have a solution
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 07, 2009 | Sony Computers & Internet
Wifi connection
try plugging the wireless mouse receiver into a different usb port
reboot your machine
is there a key on the keyboard with a little wireless symbol? if so it is probably in blue and there is fn key that you need to hold down while you press the wireless key to turn on the wireless
Feb 17, 2009 | Sony VAIO VGN-N130G/W Notebook
Wifi adapter problem with my sony vaio
Try installing the original and update wireless driver.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNSR190EBQ
And
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C455228
Dec 14, 2008 | Sony VAIO SR Series Notebook PC...
Wireless button dose not turn on
i think i got it! i had the same problem a few days ago. go to the network and sharing center in vista. then on the left pane, click on the "manage network connections" link. at the bottom should be your wireless connection. right click on it and at the top of the little menu it should say enable. and viola vaio, your little green wlan light should come on and it should connect to your wifi network. :)
Apr 08, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Adrian i have sony-vaio vgn-130g its dead no sighn
my mother board is damage. whats the cost of it.
model: acer aspire 3680-2022
email: ashokprusti@gmail.com
Jan 11, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-N130G/W Notebook Logo
570 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
