Question about Panasonic RR-930 Desktop Cassette Transcriber / Recorder
I press on the footpedal but the tape does not turn. It only reverses.
  • 207 Answers
Hello sorry but Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problemyour unit need to be send to service you can try this guys are really good.
Posted on Feb 07, 2010
The handle won't lock in upright position
On most models this is caused be a broken or worn footpedal or the notch on the vacuum where the footpedal catches is broken or worn. On some vacuums the pedal assembly is broken or has malfunctioned.
Mar 19, 2017 | Vacuums
Adjusting head on personal cassette players
there is too ways, depending on the stereo, this is for the standard type, with push puttons, there will wither be a little whole that you pop a tape in and press play and adjust the spring side up and down, but only a quarter turn either way,
or open door and pop tape directly in leaving the door open, press play and you will see the tiny screw to adjust, right side only
if its full logic or auto reverse i do not think its posible
May 22, 2014 | Audio Players & Recorders
Auto reverse
You do not list brand and model but it is typical that the belt replacement is missing the mark in that the reel rotation sensor is not detecting rotation of the reel table and therefore trying to go the other way. The reels have to be turning in play mode. If they do not auto stop or the reverse function thinks the tape is at end.
Apr 15, 2014 | Audio Players & Recorders
Needle Wont Move When Pedal Is Pressed
check if the foot pedal connect correctly or not change the footpedal if still not working
Jan 18, 2014 | Singer 2250 Tradition Basic 10-Stitch...
I have a Sharp dual cassette deck, model RT-W800. I know it is a real oldie, but would still like it to work. Tape 1 does not turn at all, either regular speed or fffwd or reverse. Tape 2 turns but does...
OPEN THE UNIT CHECK THE BELTS PUSH THE PLAY BUTTON WITH IT PLUGGED IN WITH NO TAPE IN YOU SHOULD SEE THE BELTS TURN ON THE MOTOR AND THE SMAlLER THIN BELT AT TOP IF THEY ARE TURNING LOOK IN THE TAPE FRONT DOOR WITH IT OPEN AND IN THE PLAY MODE THE TAPE HEAD MECH SHOULD RISE WHEN YOU PRESS PLAY IF IT DOES NOT REACH IN AND PUSH IT UP GENTLY CARFUL NOT TO BREAK THE SMALL WIRES AT THE BOTTOM OF THE HEAD THEN STOP THE UNIT AND RETRY PUSHING PLAY IF THE HEAD COMES UP THE TAPE SPINDALS WILL TURN CLEAN AND USE TAPE HEAD LUBE ON A Q TIP ON ALL THE MOVING PARTS WHERE THE HEAD UNIT SLIDES UP HOPE THIS HELPS THIS HAPPENDED TO MINE I STILL USE THE UNIT WORKS GREAT
Dec 30, 2010 | Audio Players & Recorders
Foot pedal operation
Hello no really you probably have a bad pedal you can buy a replacement pedal the model is RS12 at http://www.tvps.com/Products/Olympus-RS12-Foot-Pedal---New__OL-RS12.aspx
Dec 26, 2009 | Olympus Pearlcorder T2020 Desktop Cassette...
Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Mar 17, 2009 | Singer 7462 Mechanical Sewing Machine
Janome Harmony footpedal doesn't respond when pressed.
It sounds like you have a wire off inside the footpedal. If it won't work when you press it but, it will start on it's own, the wire is bouncing around inside the foot pedal box. It should either clip onto or be held in place by a screw. Other than this, it could be a broken wire, most likely where the wire comes out of the foot pedal, but this probably isn't the problem or, you need to call Ghost Busters.
Jan 03, 2009 | Singer CG754 Mechanical Sewing Machine
The footpedal in my 1209 PFAFF gets hot when I sew.
If your machine is turning easily the following applies.
This is a carbon pile foot control (Not Electronic) and when in use for an extended period of time(like doing embroidery,piecing quilts) the foot controller will get hot. There's nothing you can do about this except wear shoes.
If your machine is not turning freely, then if needs to be seen by a technician to find out why.
sewman7
Dec 27, 2008 | PfaFF Hobby 4260
Panasonic RR-930 Desktop Cassette Transcriber / Recorder Logo
156 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
