Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
  • 583 Answers
Yes, you can connect up to 4 computers to the device by running an ethernet wire between the computer and ports 1-4 on the back of the router.
Posted on Feb 04, 2010
Testimonial: "Thank you..what if the second computer is in another room? DO I need anything else to get the second computer to receive from this devise?"
  • Mark Tidwell
    Mark Tidwell Feb 05, 2010
    In order to connect to the router from another room without running a wire, you'll need to have wireless capability on the computer in the other room and you'll need a wireless access point connected to one of the four ports (1-4).
  • Linksys Master
  • 2,263 Answers
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Testimonial: "THANK YOU!!"
  • Prashant M
    Prashant M Feb 05, 2010
    well !
    This is a wired router. You said that your computer is in different room. You will need to run the cable between the cmputer and a router.
    OR you can convert this router into a wireless router. But for that you will need a device called as WIRELESS ACCESS POINT. This devie will broadcast the wireless signal.
    However your second should have wireless adapter. If it is not a wireless computer then you will need a wireless adapter for the computer.
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
How to reset Linksys RTP300 to default by code using a telephone handset connected to the device?
You can either:
1. Press and hold the reset button for more than 30 seconds while the unit is powered up.
2. Log into the Web interface, go to the "Administration" page, and perform a "factory reset" from the factory reset subpage.
May 03, 2011 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Hi Everyone! I have a Linksys Model ( BEFW 1154) Wireless model and vonage VT 2142 to be connected ASDL model internet modem with model number (DNA A201BEI). I like to know how to connect the same.
ok then first take a ethernet cable and plug it to the output of the modem and into the input of of router(for the link sys this will be known as the port labeled internet. then use the software for the link-sys and give it a network then wireless connect your computers through that network.
Feb 11, 2010 | Linksys Wireless-G Broadband Router
Vonage router settings
Are you able to go online when you connect the computer directly to the modem ( without the router ) ? If you are online with the modem, then you can set up the router manually.
Click Here for step by step solutions
Nov 03, 2009 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys RTP300 Broadband VOIP router W/2 phone ports
Have you tried to do a hard reset on the unit?
Apr 05, 2009 | Computers & Internet
Hooking up Vonage to Time Warner Roadrunner(dsl): Do I have to buy a Linksys Wireless device for my Vonage to work?
You just need a router. and then plug the vonage device onto the router.
Note: make sure you have internet with the router before pluggin the vonage device to it.
Aug 15, 2008 | Linksys Wireless-G Broadband Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
197 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
