Question about Keurig Elite B40 Coffee Maker
Our coffee tastes very weak. Would de scaling help.
  • afischesser Feb 04, 2010
    Thanks,
    We are using k-cups and it just does not taste as strong as it used to. They are k-cups that are with a good date.
    President:
  • 949 Answers
This would not hurt, but I think you just need to add a tablespoon or two more coffee grounds or until it is the strength you want.
Only the heat of the water will give you poor quality, the hotter the water
the more coffee comes out from the grounds.
Posted on Feb 04, 2010
  • odiebugs
    odiebugs Feb 04, 2010
    Your welcome, yes, try cleaning the unit, as this could help the
    water get hotter as it enters the coffee.
I have the same problem. I thought maybe it was just because I have been drinking espresso and now the coffee seems week to me but it isn't even weak so much as it has no taste. I have just descaled and I thought maybe it was because I didn't flush out the vinegar enough. One other thing, the temperature also seems hotter. I can barely touch the side of the cup now when removing it and I know it wasn't like that before. If you are able to fix yours I would love to know the solution.
Posted on Feb 22, 2010
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Krups 453 - coffee is weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
De-scale light came on. What do we do???
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 02, 2011 | Keurig B100 Coffee Maker
Tip
De-Scale Keurig coffee units
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
on Dec 22, 2010 | Coffee Makers & Espresso Machines
My coffee maker has the words de scale in the corner or something like that. Also all the lights are not coming on except the one for the most amount of coffee and it just trickles down to not even half a...
Dec 25, 2010 | Keurig B60 Coffee Maker
My coffee maker heats up brews but not makeing coffee just pooring out water all over
dsfds
Dec 24, 2010 | Keurig B60 Coffee Maker
Lacks pressure when making coffee
Dec 23, 2010 | Keurig B30 Mini Coffee Maker
De-scale message appeared. Followed instructions in manual. Product not working. Everything smells like vinegar. Now what???
you should have done whats below, it may need to be done twice...last but not least..you have to put more fresh water in to remove the taste
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
Water flow is weak and slow during brew
bcvb
cbcb
cvbcbc
Dec 23, 2010 | Keurig B60 Coffee Maker
My coffe is tasting salty-its awful
234999fff Sorry to read about your issue.
Dec 22, 2010 | Keurig B60 Coffee Maker
My Keurig B60 SE has recently started brewing k-cups very, very weak. I have a filter that I can put coffee in and that works fine, and I've even found that when I put the coffee from a kcup into the...
Sorry to read about your issue. plus you may have a bad k kups
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
De-scale botton blinks all the time
42n2nn4
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
268 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
