Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer squeaks when you start. warms up it goes away
  • 32 Answers
It may be one of the tensioner pulley wheels either starting to fall apart or the spindle it runs on in need of a little grease. They often start off squeaking until they've warmed up a little. Then the noise goes away after 5 minutes or so.
Posted on Feb 04, 2010
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Unusual squeak noice
easy way is a bit of furniture pollish on belt / fly wheel
Jul 23, 2010 | Kenmore 74602 Gas Dryer
Sounds like your motor and/or pulley assembly are bad. Try turning the drum by hand. If it turns with some effort then you may have a drum bearing going bad. Does the squeaking sound start right away? Or does it start when the dryer warms up? If so then the bearing is going. If you can get to it spray WD40 for a quick fix.
Jul 11, 2010 | Frigidaire Dryers
Dryer makes squeaking, rattling noise whe starting. Goes away after a couple of minutes.
sounds like your bogie wheels may be starting to ware out they are bottom left and right drum inside front panel if worn they take 10 mins to replace
Dec 18, 2009 | LG DLE2532W Electric Dryer
I have an Amana (M# ALE643RBW), when started the dryer squeaks for the first 10 minutes of the cycle, then slows to a squeak every 7 minutes... why? Maybe a bit of lube?
I have the same problem. While I have not fixed it yet, I assume it is a drum roller. Most dryers have two 4 to 5 inch diameter drum rollers which hold up the dryer barrel in the back. These drum rollers are wheels which have rubber on the outside where they touch the drum and a metal hole in their middle. They turn on a metal rod which goes through their middle. As the inside of the wheel turns on the rod, the metal gets eaten away and they squeak. Replacing one or both drum rollers should fix the problem.
Nov 25, 2009 | Amana Dryers
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
Squeaks FSE446RHS2 XD41513722
You can generally access the unit from the rear panel. Try and lube the joints around the pully for the belt and any other moving parts. Hopefully you won't have to replace any parts. Good luck
Apr 10, 2009 | Frigidaire FSE748GF Dryer
There is a squeaking sound when running the dryer
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Nov 28, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer
Your machine uses a belt tensioner of the type that the belt 'glides' on, creating a squeak noise that #1 will get worse and #2 is wearing out the belt. Replace the old tensioner with the one pictured here. The squeak will go away and the belt will last longer.
If you need further assistance, or instruction on disassembly, let me know
Regards,
reg501
Jun 27, 2008 | Roper RGX4634KQ Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
503 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
