Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
The lamp light came on below the on/off switch and a week later the tv came on when I tried it. Now the lamp light is on again. Is it possible for the lamp to burn out, work briefly, and then die for good. I don't want to buy a new bulb if it is not the bulb.
  • Sony Master
  • 8,457 Answers
Yes lamp is dead need replacement.Tries Partstore.com,Ebay.com for the part.
Posted on Feb 04, 2010
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Temp light flashes and then shuts down
hi,
possiblely it is the problem of fan, try to check the radiator fan port.
later use the machine, shut off it, until the lamp fully cool.
regards
Jack
WHOLESALER AND RETAILER FOR BELOW PRODUCTS:
projector color wheel, lens and bulb, remote, lamp power, mother board. all brand and most of model.
computer mother board, memory, harddisk,
HP server, switch, and router.
Nov 21, 2011 | Optoma MovieTime DV10 Multimedia Projector
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Changed the lamp and the lamp light came back on. A week later i tried to turn tv on and the status light keeps blinking,and tv will not come on. What can i do to repair myself?
There's a possibility that you might have a defective ballast, or another component form the light engine system, for a better deduction of what might be the issue, discountdasmerchantdotcom the troubleshooting is free
Jul 09, 2009 | Televison & Video
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Sony KDS-R50xbr1 50" Problems
Here's the best way to get Sony's and/or the extended warranty company's attention and possible help.
Send an old fashioned letter to Sony and your extended warranty provider outlining the problems and your concerns regarding your TV. Make sure to prominently indicate that a copy of the letter is being sent to the complaint division at the attorney general's office in your state. After having to settle claims surrounding their optical block (light engine) issues Sony now understands that failure to address their customer's complaints may result in another judgement against them.
Good luck and give 'em hell!
michtech
Jan 27, 2009 | Sony KDS-R50XBR1 50" HDTV
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
