Question about GE JVM1440 Microwave Oven
GE Spacemaker microwave XL1400
My microwave was working, but when I opened the door a few seconds before the timer went off, it stopped working completely. I checked the main fuse panel and it was fine, so I suspect I've blown an internal fuse. There is a panel at the top of the inside of the unit with open/close arrows. I suspect this may be for servicing, and could contain the fuses. Can you offer any suggestions?
  • Anonymous Dec 24, 2008
    Everything was working on the microwave except it was not getting hot inside and heating the food. Checked the power level and it is on 10. Pulled the plug and replugged it. Still did not heat up inside. Finally smelled an order like something is burning. So we unplugged it. Do we need to buy a new one. It is about 7 or 8 years old.
  • GE Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
Ge spacemaker microwave xl1400 works but does not heat
Pledase check the operation of the door safety interlock system. If you routinely open the door while the oven is operating, these small switches will eventually burn out and not work.
Oct 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable on our XL1400 stopped working. Is
the diskmotor is defect?
mesure the resistor of the motor with reduction under the plate the value must be bethween 60 and 100 Ohm.
if not the coil is burnd and you have to replace the motor.
Feb 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker xl1400 microwave quit heating. worked fine, timers, clocks and everything else is fine
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
lkkg
Nov 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you remove the vent grille held on by screws and/or clips then you'll see a screw at the top of the control panel.
Then the control panel should either lift up and out or forward and down.
The fuse is normally near the door switches, on the floor behind the controls, or on a metal plate near the transformer or fan.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The actual model number is like JVM1460. XL1400 is just a "line" and won't help in finding parts.
Mar 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
197 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
