Question about Panasonic CT-27SC14 27" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and reconnected.
    Problem Solver:
  • 5 Answers
Hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Posted on Feb 20, 2010
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Lightning hit last night tv won't work cable company says it's in the television
Sorry to here about your problem! This is the time of year I used to get tons and tons of sets, stereos ,games, and vcrs in for repair. On your panasonic it seems that maybe the surge took out the tuner portion or the power supply. It sould cost aprox. 200 bucks or so for a new tuner. Im sure your aware that homeowners will cover almost all repair after the deductable. Good Luck
Jun 04, 2006 | Panasonic CT-36G24 36" TV
Panasonic CT-27SC14 27" TV Logo
269 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
