Sky not working properly on my samsung lcd tv
When changing channels, or at advert breaks the tv flashes the picture on and off. it does this sometimes at scene changes in a program as well. it falshes maybe four times when changing channel and then settles down and is fine, however, during some advert breaks, it will flash all the way through it. the tv is only a year old, and has had no other problems. it worked fine on free view, cable, pc and games consoles. just blooming sky
  • paulythedogg Feb 20, 2008
    Thanks
  • paulythedogg Feb 21, 2008
    thanks for your help. Much appreciated. I have tried this solution and it makes it better, but still get flashing, but in colour this time. our sky installer has fitted and old thompson box and this has solved the problem....any ideas why or how?
  • 476 Answers
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Posted on Feb 20, 2008
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung LE32R7 Picture Flashing
You need to get your sky box changed! just ring them up and tell them your problem. the TV is a known issue with certain boxes.
Feb 14, 2008 | Televison & Video
Lg lc55
i have lg 42" lc55 model and had the screen smashed any ideas if it can be replaced!!!!!!!!!!!1
Jan 11, 2008 | Televison & Video
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
