Question about Garden
Timing a briggs and stratton 12.5 h.p. mod# 286707 help me please dont know if im 180 degrees off or not
  • alboc65 Feb 05, 2010
    thank you very much its been a while since i did this thanks again god bless
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere L118 stalls after it runs
2 problems are common with this machine.One is the earlier machines had bad placement of the fuel line at the tank causing it to get pinched off and restrict fuel flow.It may get pinched at the very top of tank where line starts or between very rear of tank and frame.2nd problem is with the decompression setting of the valves causing engine to have too much compression at start up.Set your valves when piston is a 1/4 inch past top-dead-center.Set your intakes at .004.
Posted on Nov 14, 2009
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
What type and quatity engine oil
30w or 10w30 automotive engine oil... buy a quart and start with about half. and check it correctly
Aug 25, 2014 | Briggs & Stratton Garden
How to time a briggs and stratton engine ohv
pull it apart again and reset the timing as you are out 180 degrees . Place the piston on top DC with the valves in the valve rock position . ( exhaust nearly closed with inlet just starting to open) This will align the timing marks between the crank gear and the cam gear.
Apr 20, 2014 | Cars & Trucks
After cleaning and lubing a Briggs and Stratton started, it turns in the reverse direction. What is the problem?
I am guessing but I take it that you have ran it before and you didn't have this problem?
I ask because some Briggs -n-Stratton engine are made to run backwards.
Although I am unsure why these motor were designed with this intend.
If this is a new problem the only logical explanation is the timing is off. Off meaning around 180 degrees. This can happen if the flywheel shears the woodruff key. However since a backward running motor is not logical I suppose we can through that out the window.
Please respond with the model Briggs-n-Stratton motor and I will try and come up with some illogical solutions to the problem.
Hope to hear back.
It might help to remember that given the possibility that there is an infinite number of universes, there is at least one that your motor would be running in the correct direction. It's just not this one.
Nov 24, 2009 | Briggs & Stratton 6200 Watt Electric Start...
I need to know the timeing for valve to piston
valve timin can be achieved by aligning the timing marks on the crankshaft and cam gear respectfully. if the marks are worn off then it will be difficult to time without a degree wheel. im guessing u are repairing a briggs and stratton engine but they all time in the same manner. good wrenching!!
Nov 11, 2009 | Craftsman Garden
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mower starts but when you take your foot off the clutch it stops
sound like the seat saftey switch under seat you can either unplug it and see if that works or jumper the wires with a piece of wire if either works replace switch
Mar 24, 2009 | Craftsman Laser Level - Sears 180 Degree...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
