Question about Ricoh Aficio 1018D All-In-One Laser Printer
Network printing We can see the printer on the network but cannot print to it.
  • 1 more comment
  • Bilseville Feb 25, 2008
    Yes that was the fix. Wish I would have seen it before repair man was here!
    How do I clear the password? Service man couldn't do that!
    When we go to the printer using the ip address it wants a password to log into the machine so we can make changes. Right now we can only make changes from the front panel on the machine.
    By the way it is actually called an 1802d Gestetner but they said it's the same thing as a Aficio 1018D.
  • Bilseville Feb 26, 2008
    I tried both and neither one worked. Someone has changed it in the past i guess. Service probably. Anyway to reset the password?
    Also. I sincerely thank you for all your help.
Help full friend
Posted on Oct 22, 2012
Sc194
Posted on Jun 28, 2011
What password are you reffering to?
Posted on Feb 25, 2008
  • 87 Answers
If you can see it, it is set up right, however, the configuration might be wrong. Go to printer properties in the control panel. Open up the ports tab, select configure port. You will see that it is probably set: protocol:Raw, port:9100. Sometimes the port is 10001. Otherwise, set it to LPR, and put LP1 for the queue Name. That should do it.
Posted on Feb 23, 2008
  • 1 more comment
  • Dale Richards
    Dale Richards Feb 26, 2008
    The user name is: admin
    The password is blank.
  • Dale Richards
    If that is not it, try : sysadmn
  • Dale Richards
    OK, last resort. I gave you:
    username: admin
    password:
    Password: sysadm
    last one!
    username:
    password:password
    I can't remember the configuration of that machine off the top of my head. If you try all of those, then yes somebody changed it.
    In that case, you can do a memory all clear, but there is alot of reprogramming that would have to be done. You would virtually have to resetup the machine. It is not recommended, because at setup, everything is new, and settings are based on that fact.
    Lets hope one of the above does the trick.
Network printer if print test page printing normaly if print pdf or word not printing !!
The test page comes from the printer itself. If the printer is on a network you need to re-establish it on the network using its IP address. If it is a network printer on one computer, you need to redownload the software.
You should also go to Settings/Printers and make sure the machine itself is the default printer rather than some type of Windows virtual printer like 'Print to File' or 'Print to PDF', Print to Fax' or a printer that is no longer there.
Nov 18, 2015 | Office Equipment & Supplies
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Ph8000 prints a network configuration page every time I print
Go into your settings under reports. You should be able to adjust to your liking.
Sep 28, 2012 | HP Officejet Pro 8000 Wireless InkJet...
Won't print to network printer
do you print it to the computer were the printer were you want to print or to another computer were the printer is installed to other computer and you trying to print it by search it to the network to print..if it is the same OS that you are using there is no problem on it..but if it is different OS like you likr to print it to the pc if it is win 7 but the printer is connected to a pc were win xp is the OS he/she using you must install it again..go to youtube and search..how to print to other pc by network.
Dec 08, 2011 | Brother MFC-8480DN All-In-One Laser...
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
Can HP 1410 printer support LAN.
HP 1410 is not a network printer. If you want network printing, you must purchase a printer that features network printing.
You can designate a pc to act as network server and plug printer into that server, and then print from another computer on the same network
May 28, 2009 | HP PSC 1410v All-in-One Printer
Fs-3900 intermittently not printing
for FS-3900DN the latest firmware is the one what you have. BUT there is a separate update firmware for the Network Card !!
Check if you have installed the latest print driver in ALL computers and the OS updated with the latest patches.
Q1: The printing issue is consistent when you change computers ? IF yes THEN the issue is within the printer or the network.
Then:
Check if you have same issues when printing using the USB (not the network).
IF is printing OK when you use the USB but you got trouble using the network THEN something is wrong with the network printing so:
-> connect the printer straight to a PC/laptop using a crossover network cable that so you bypass the whole network (LAN) hardware.
--> IF is printing OK THEN the problem is within the network hardware(LAN) - you may try to pinpoint by replacing the network cable between the hub/router and the printer.
--> IF printing using the crossover cable is NOT OK then the problem is in the printer's network card. Check if the jack or the cable fit well into the printer or if the connector is not loose.
IF printing using USB is NOT OK then the problem may be into the printer. Reload the firmware engine and system + network card... it may help.
Q2: When you say: "fails to print unless it's powered OFF / ON" you mean the print job what you sent is waiting into the computer print spooler = the printer is being seen as NOT READY ? or the print job is just missing and you have to restart the printer and after that resend the print job ? ou can chack the printer stat by going to her IP address = open any internet browser and type the ip address. You should see a web page. Check the printer status before sending any print job.
Oct 27, 2008 | Kyocera FS-3900DN Laser Printer
Printing only test page
when you click on the print in Microsoft Word is the printer there, is it set as the default printer?
Try this:
 click on File
Print
right click on the printer
go to Properties
Set as default printer
Oct 25, 2007 | HP LaserJet 4 plus Printer
Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Aug 08, 2007 | HP Photosmart C6180 All-In-One InkJet...
Ricoh Aficio 1018D All-In-One Laser Printer Logo
733 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
