Question about Boating
1981 evinrude 115HP outboard - The wire connecting
1) The wire connecting the power pack to the coils (at the joining point) is marked A & B. Does the A wire from the power pack go to the coil for cylinder 1 or 3.
2) If the motor does not start immediately and you try to start the motor by turning the key for say 30-35 seconds should the starter motor get quite hot as a result
1) I cleaned the terminal ends and whether or not I mixed the wires up again, I really dont know but I managed to get the motor started.
2) I took the starter motor apart and cleaned the plates which make contact with the brushes, this made quite a difference to the working of the starter motor.
Posted on Feb 06, 2010
I have a 1981 johnson 75hp charger. blew powerhead so i bought an evinrude powerhead that was omc identical. I have no spark. wiring issues.Thought johnson and evinrude was same wiring?
go google and type in --wiring schematics for johnson outboard motor 75 hp 1981 model --- and see if there is a pdf version for down load
repeat the search but change the name to evinrude and look for a pdf version down load
go to a dealer service center and see if you can get a schematics for each from them
while it can be expected that the wiring should be the same as each brand is made in a different factory there could be a slight difference in the wiring set up that is causing the problem
Aug 09, 2016 | Boating
How do i wire an internal wire harness on a 115hp mercury outboard
Google outboard engine wiring color codes
Sep 11, 2014 | Boating
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
I have a KZ 1100 that lost spark on number 2 and 3
Try to change coil from one side to the other, if the spark goes to 2 & 3 but not 1 & 4 you need the coil replaced or find the power loss (blown fuse) .I have not worked on that bike so am not sure. also color code on wires in the harness will be enough to follow wires without the book,no need to cut them open just note the colors at the point you are trying to check,follow along the way untill that color comes to a conector. or to the fuse buss or device.A multi meter can check condition between points Hope that will help you good luck .Joe
Mar 26, 2010 | 1981 kawasaki KZ 1300 A3
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
1984 150hp yamaha outboard is not firing in #5
Stator delivery to the coils.
Sep 20, 2009 | Boating
Boating Logo
185 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
